How much HP?
Old Apr 18, 2013 | 11:19 PM
Fastang97's Avatar
How much HP?
Wondering how much HP a Pi swap will give the sn95's? Also does a Pi swap affect the car if you plan to Fi?
Old Apr 18, 2013 | 11:57 PM
1999Pony's Avatar
You'll be even with the 99-04's. 260hp crank hp. And it will only make going FI that much better.
Old Apr 21, 2013 | 08:05 AM
97GT03SVT's Avatar
You should get a little mire power with a pi swap on a non pi motor because of the higher compression you will make. Some people get around 280hp with the swap, you also will need to use premium fuel with the swap.
Old Apr 21, 2013 | 06:56 PM
Fastang97's Avatar
Ok thanks.
