HELP my 5.0
HELP my 5.0
Hello I have a problem just recently with my car when I drive it in about 3rd gear and up around 2500 Rpms it kind of sputters like a slight tug/jerks it's very annoying especially when I try to get on it
Any suggestions???
Any suggestions???
Any suggestions???
Any suggestions???
I checked all sprk plugs wires are
Good even put
New intake cleaned throttle body and censor still the same prob and cleaned injectors
Think it's fuel filter????
Good even put
Good even put
Good even put
DO NOT Throw parts at it, it's the dumbest way the fix a problem. Check your fuel pressure with a gauge while your driving and the surging is happening. Also have a vacuum gauge hooked up at the same time. If the fuel pressure is steady, but the vacuum is bouncing you most likely have a bad EGR valve or leaking valve. If the fuel pressure is dropping check the pressure before the regulator, if it's ok the regulator is the problem , if not it's your fuel pump.
Remember just changing parts will do only one thing, COST YOU MORE MONEY, plus you won't learn anything for next time you have a problem. good luck.
