HELP my 5.0
Old May 14, 2012 | 08:41 PM
Ricerkiller91's Avatar
HELP my 5.0
Hello I have a problem just recently with my car when I drive it in about 3rd gear and up around 2500 Rpms it kind of sputters like a slight tug/jerks it's very annoying especially when I try to get on it
Any suggestions???
Old May 14, 2012 | 09:01 PM
Dbranham's Avatar
Check spark plugs first.
Old May 14, 2012 | 11:42 PM
shaunrc's Avatar
Any suggestions???
Could be spark plugs could also be plug wires I had the same problem with my 2000 gt
Old May 16, 2012 | 08:47 AM
I checked all sprk plugs wires are
Good even put
New intake cleaned throttle body and censor still the same prob and cleaned injectors
Think it's fuel filter????
Old May 16, 2012 | 08:56 AM
Dbranham's Avatar
Good even put
Would never hurt to have the fuel filter change. I have one for my car just haven't got around to changing it out.
Old May 16, 2012 | 09:04 AM
sampey43's Avatar
Good even put
Your definitely on the right track! Eliminate all the small, cheap stuff first, then when you find the problem, have it fixed, and all the other stuff you did will be done and out of the way for awhile
Old May 16, 2012 | 09:06 AM
sampey43's Avatar
What year is your 5.0?
Old May 22, 2012 | 11:15 AM
It's a 94 I changed fuel filter still the same
Old May 22, 2012 | 01:58 PM
automan1954's Avatar
DO NOT Throw parts at it, it's the dumbest way the fix a problem. Check your fuel pressure with a gauge while your driving and the surging is happening. Also have a vacuum gauge hooked up at the same time. If the fuel pressure is steady, but the vacuum is bouncing you most likely have a bad EGR valve or leaking valve. If the fuel pressure is dropping check the pressure before the regulator, if it's ok the regulator is the problem , if not it's your fuel pump.
Remember just changing parts will do only one thing, COST YOU MORE MONEY, plus you won't learn anything for next time you have a problem. good luck.
Road_Runner
Sep 2, 2024 04:46 PM
Infamous_blackbeard
Oct 8, 2015 10:45 PM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
Bryanh24
Sep 16, 2015 08:31 PM
Cdvision
Sep 5, 2015 05:22 PM
