Help on how to remove hood scoop insert
I have a 2001 mustang gt and want to remove the insert from the hood scoop. Any done this? And can you tell me how you did it?
Thanks for any help you can give!
Open the hood there is a heat shield on the bottom of the hood. It is held in by little pins. Pry them out with a screwdriver. Now there should be 4 bolts visible that line up with the scoop on the
underside of the hood. Remove those and pull off the scoop. It will be dirty under there.
9/16/15 06:44 PM
