Help on how to remove hood scoop insert
Old Mar 25, 2012 | 06:27 AM
1998ponypower's Avatar
I have a 2001 mustang gt and want to remove the insert from the hood scoop. Any done this? And can you tell me how you did it?
Thanks for any help you can give!
Old Mar 25, 2012 | 07:32 AM
NYGMEN's Avatar
Open the hood there is a heat shield on the bottom of the hood. It is held in by little pins. Pry them out with a screwdriver. Now there should be 4 bolts visible that line up with the scoop on the
underside of the hood. Remove those and pull off the scoop. It will be dirty under there.
Old Mar 25, 2012 | 08:34 AM
cpotts13's Avatar
Why?...
Old Mar 25, 2012 | 01:43 PM
Thanks for the info! I want to repaint the insert.
Thanks again
May 3, 2026 05:42 AM
yabutt
Oct 23, 2015 01:05 PM
TerryD
Sep 28, 2015 11:48 AM
Sep 16, 2015 06:44 PM
