going carb? anymore power?
i was talking to a racer at the track and he was telling me to go carb. and i would get more power and a better time. is any of that true. i don't think i could swap my car. i drive it everyday everywhere.
to go to carb you'll have to pull the efipump out of the tank install a timing cover with the mounting place for a mechanical fuel pump and get a 4bbl intake or get aftermarket fuel rails and a bypass fuel pressure regulator so the carb will only get 5-7 psi of pressure and the rest goes back to the tank the 45 psi that the in tank pump puts out will blow all the seals out of a carb
for a daily driver, stick to EFI. carbs have come a long way though, but EFI has proven itself very adaptable to the different operating conditions a daily driver is subject to.
I don't think you would get any more power out of a carb unless you drastically changed the intake. For the money involved, you can do a lot more to a EFI setup to make more power.
emissions.. is not a priority of mine.. its not emissions legal anymore.. i didn't plan on changing to carb because i of the MPG. i am getting frustrated with my EFI i can't get my intake backfire to go away. i think it might be ruining lean.
A lot of backfires are caused by something being wrong with the spark and when it goes off relative to the position of the piston, not how much fuel is going through the engine.
it only does it when i am at an idle and i hit the throttle to rev it up. and it pops. and its sluggish to take off when i start it up but once i get to 3rd gear i am good from then on?
hahahaha switching from fuel injection to a carb that does not make any sense to me unless your someone that likes wasting money to make your engine less efficent or your someone who likes to work on their car using an arrow heads to adjust their a/f ratio
Rando
8/25/21 11:12 AM
