Clutch Kit Recommendation
Old May 22, 2012 | 08:07 AM
Chubbs88's Avatar
Hey all. I have an 02' GT with minor work done... Pretty much every bolt on you can think of. I have plans to install .410 gears and possibly nitrous. I burned out my clutch doing donuts (dumb but fun) and am ready to purchase a new clutch and flywheel right now. I'm debating if I should go with a Centerforce Dual Friction Clutch or a Spec Stage II + . I'm not a huge fan of heavy clutches... And I want to make sure I get the best bang for my buck.... Something that will last me a while (I'll chill out on the 2nd gear donuts). I plan on buying a Fidanza Aluminum Fly wheel, Ford Racing throw out bearing, and an Ford Racing pilot bushing.
Please give any thoughts or experiences you may have on any of this. Thanks!
Old May 22, 2012 | 09:13 AM
Dbranham's Avatar
I've never heard anything bad about a center force duel friction
I had a spec stage III or a few months before I burned it out
Old May 22, 2012 | 09:22 AM
AlsCobra's Avatar
A Man Just Needs Some....
Spec 2+ will do fine. Not a big fan of centerforce but supposed to be a good clutch also. Ford Racing throw out bearing is a must.
Old May 30, 2012 | 07:01 PM
soupnutz's Avatar
I don't have anything outrageous, just basic bolt ons, but I've always gone with cobra clutches. Never had any issues and I beat the **** out of it.
Old May 31, 2012 | 09:18 AM
Chubbs88's Avatar
I went with the Centerforce clutch and Fidanza aluminum flywheel. I also will use the ford racing Throwout and pilot bearings. Thanks for all the feedback. I'll let ya guys know how it turns out.
Old May 31, 2012 | 08:55 PM
Dbranham's Avatar
Make sure not to pull it hard till it breaks in. Usually about 500 miles.
Old Jun 4, 2012 | 12:23 PM
Chubbs88's Avatar
Installation went smoothly. So far I give two thumbs up! Minimal chattering... The clutch is light, smooth, and seems to grab effectively (during normal driving). Not sure of the aluminum flywheel results yet. I am waiting for the 500 mile break-in point to give her hell. I'm expecting to lose a little bottom-end torque when launching... But am hoping the rpm upper-end reaction will make up for it while moving through the gears. If I feel too much has been lost on the launch... I'll throw in 3.90 gears!
Old Jun 4, 2012 | 01:49 PM
skunk21's Avatar
why do think you will low loose end on a clutch/lighter flywheel change? A lighter flywheel takes strain of the motor and allows it to rev more freely, it is able to release more power faster than the heavier stock flywheel. The only down side is the lack of the rotational mass is that it doesn't store has much rotational energy has the stock flywheel so lighter flywheel is more prone to speed changes under certian loads.
Old Jun 4, 2012 | 01:53 PM
AlsCobra's Avatar
I'm sure that's what he's talking about. A little less push at lower rpm launches.
Old Jun 4, 2012 | 01:58 PM
skunk21's Avatar
how low does he want to launch . motor should spool up quicker now. I would do gears anyways when he gets the chance.
Old Jun 4, 2012 | 02:03 PM
AlsCobra's Avatar
I think it just feels different to him. Once he's used to it, he should be able to notice the advantage of the lighter flywheel.
Old Jun 4, 2012 | 02:07 PM
skunk21's Avatar
No doubt about that.
Old Jun 4, 2012 | 02:50 PM
Chubbs88's Avatar
Yup... I was only thinking of the initial loss of inertia. Once she's broken in I will be able to get a better feel. Thanks for all your guys' input!
Old Jul 3, 2012 | 12:04 PM
Chubbs88's Avatar
Clutch is broken in... Gave her some hell. The clutch grabs beautifully and the pedal is crazy light! The flywheel definitely affects my launch and requires me to give more RPMs to make up for the loss in initial torque. For now... I will launch at higher RPMs ... But I definitely am going to look into installing 4.10 or 3.90 gears.
Road_Runner
Sep 2, 2024 04:46 PM
Gill5oh
Oct 6, 2017 10:50 PM
wallace
Mar 29, 2016 10:09 AM
09-gt/cs
Oct 15, 2015 10:03 AM
GeoWett
Sep 30, 2015 06:40 AM
