(04 Mach I) Normal Warm Idle oil pressure?
Can someone tell me what the Normal Warm Idle oil pressure is for a stock 04 Mach I motor is. I'm looking to purchase a Factory Five Cobra with a 04 Mach I motor but the guy says it runs a low idle PSI when warm. Something like 20-22 PSI. What is the normal oil pressure (PSI) for these motors Any help would be much appreciated.
Thanks,
Scott
Thanks,
Scott
Thanks TJ4Cam. That seems like a very wide range. 138-310 kPa translates to 20 - 45 PSI.
Do you have an oil presure gauge in your 03 Mach I? Can you tell me what your idle oil presure is after the car is warm?
-Scott
-Scott
Hi Scott, no, I do not have a gauge. You may want to ask your question to the guys at the Mach 1 Registry though, lots a smarties over there!..............www.mach1registry.org best of luck!
