(04 Mach I) Normal Warm Idle oil pressure?
Old Jul 14, 2008 | 01:30 PM
srichard's Avatar
Can someone tell me what the Normal Warm Idle oil pressure is for a stock 04 Mach I motor is. I'm looking to purchase a Factory Five Cobra with a 04 Mach I motor but the guy says it runs a low idle PSI when warm. Something like 20-22 PSI. What is the normal oil pressure (PSI) for these motors Any help would be much appreciated.
Thanks,
Scott
Old Jul 14, 2008 | 02:06 PM
TJ4Cam's Avatar
My Ford shop manual says........Oil Pressure (Hot 1500 rpm) 138-310 kPa......You would have to convert that to psi.
Old Jul 14, 2008 | 02:22 PM
srichard's Avatar
Thanks TJ4Cam. That seems like a very wide range. 138-310 kPa translates to 20 - 45 PSI.
Do you have an oil presure gauge in your 03 Mach I? Can you tell me what your idle oil presure is after the car is warm?
-Scott
Old Jul 15, 2008 | 08:31 AM
TJ4Cam's Avatar
Hi Scott, no, I do not have a gauge. You may want to ask your question to the guys at the Mach 1 Registry though, lots a smarties over there!..............www.mach1registry.org best of luck!
Old Jul 15, 2008 | 08:39 AM
Evil_Capri's Avatar
http://www.mach1registry.org/forums/...pressure+gauge
This may help. As TJ stated the guys on M1R have much information available.
kponypower
Jun 17, 2020 07:17 AM
southern stang
Sep 26, 2015 04:19 PM
Jailbirdwatcher
Sep 25, 2015 06:39 AM
