Running twin m90 superchargers
I've decided to just rebuild the supercoupe engine from ground up and put the whole thing together outside of the car and then swap the engines out. It'll give me a new engine and save probably a months time.
Its an interesting idea for sure. Definitely keep us posted as things go along an parts strt rolling in! ![Thumb](https://themustangsource.com/forums/images/smilies/thumb.gif)
I saw a video pf a challenger with dual blowers, a monster cam too. Its definitely possible, and definitely one helluva accomplishment when you finish it up
Needs to be more Astony
You will definatly need much larger fuel injectors and fuel pump. I'm sure a 255lph fuel pump would be fine, injectors I'm not sure since you would need bigger on a 6 for same power as an 8.
Here's a picture of the twin blowers unpainted.
I'm getting some off AM that are good up too 450hp! I got all the parts yesterday and sand blasted them all tonight. Monday they will be sent out to be stripped and acid washed and then powder coated blue to match the car.
#40
