Running twin m90 superchargers
Old Mar 7, 2013 | 03:48 PM
rodsoccer2's Avatar
Two days ago I just purchased a 1990 supercoupe 3.8L engine ad well as two m90 superchargers. I have seen a couple pictures of people running both. I saw this one guy had them stacked on top of each other. Does anybody know how to run both of them like that or have any tips that could help? I talked to an AM worker and he said running both with the proper tune, CAI, and fuel injectors, it would put me close to 400bhp.
Old Mar 7, 2013 | 04:00 PM
bluethunderhorse's Avatar
It would be better to mount them side by side. To do that you would have to have a custom lower intake, fab up some idler brackets, and have a custom air intake. If you mounted them on top of each other you would have to have a very tall hood, a custom intake to go from the outlet of one, to the inlet of the other, a custom air intake, fab up idler brackets. Either way lots of work and lots of research will be needed.
Old Mar 7, 2013 | 04:29 PM
rodsoccer2's Avatar
I'm running them to a 98 mustang so the lower intake won't be a problem. What do you mean by custom air intake?
Old Mar 7, 2013 | 04:35 PM
cold air intake
Old Mar 7, 2013 | 04:40 PM
rodsoccer2's Avatar
cold air intake
That makes sense!:P I'm not doing this until the summer but I'm wanting to get it completely ready and have everything that I need before I do the install. Is there enough room to run them side by side?
Old Mar 8, 2013 | 08:28 AM
Dbranham's Avatar
I wonder what kind of hood you would need for clearance. That be sick if you didn't have to get a 6in crowl hood. Maybe a cobra r hood Would work?
I remember seeing somewhere forever ago some place makes a 96-98 cobra hood with a 3(I think) inch crowl hood and it looks so good, haven't seen it since then thou.
Old Mar 8, 2013 | 08:54 AM
I don't know if a 3 inch hood will clear it, and 6 inches make it look like you're trying too hard. I'd go side by side, it'll look cooler too!
Old Mar 8, 2013 | 09:01 AM
Blackout's Avatar
I wanna see this if you actually follow through with it
Old Mar 8, 2013 | 09:43 AM
rodsoccer2's Avatar
If I went stacked I'd just make a cut out and put a hood scoop ove the 2.
Old Mar 8, 2013 | 09:45 AM
rodsoccer2's Avatar
I'm definitely following through with it. It's going to be a slow process though. Ill most likely run them side by side so I don't have to do any custom work.
Old Mar 8, 2013 | 01:45 PM
Blackout's Avatar
Yeah just do a little at a time and ya got it do you have a picture of the dual blowers
Old Mar 8, 2013 | 02:04 PM
rodsoccer2's Avatar
Ill put some pics up when they come in. Ups picked them up today.
Old Mar 8, 2013 | 02:42 PM
You got options on the side by side deal
Either way lots of fab work
Old Mar 8, 2013 | 02:48 PM
Blackout's Avatar
Not bad at all.
Old Mar 8, 2013 | 02:54 PM
What's the point? Why not get a bigger one rather than all that fab expense.
Old Mar 8, 2013 | 02:57 PM
Blackout's Avatar
It's what he wants its what he's asking advice on, and a person deserves to be happy, so support.
Old Mar 8, 2013 | 04:12 PM
rodsoccer2's Avatar
Because I got them for ridiculously cheap so no matter how much custom work I have to do ill still save 3-4 thousand dollars. It'd be way over 5,000$ if I got a full kit on AM.
Old Mar 8, 2013 | 04:14 PM
rodsoccer2's Avatar
Exactly!👍
Old Mar 12, 2013 | 03:41 PM
rodsoccer2's Avatar
Will I need a new fuel pump? If so what kind??
Old Mar 12, 2013 | 03:49 PM
Yes, aftermarket 255lph. Factory SVT Focus, or Twin 03 cobra units
