Gas Leak
Old Jul 10, 2006 | 02:12 PM
mudshuvel319's Avatar
If there's an actual rubber gasket, I would assume that the pipe is bolted to the tank. If that's the case, order the new gasket from a Ford dealer, and try crawling undre the car and unbolting the pipe and replacing the gasket.
However, I'm surprised that there would be only a bolted connection instead of a weld, so check that this is the case. Also make sure that there are no cracks or holes in the pipe or around the pipe-tank seam. If thats the case, it'll be more difficult to fix.
Old Jul 10, 2006 | 03:06 PM
MY05GT's Avatar
There is a grommet that seals it up. My Cobra started leaking there badly on day one ( day one for me was last December ). I had the dealer fix it. Cheap part, reasonable labor.
Old Jul 11, 2006 | 06:09 AM
tricky02GT's Avatar
Had this problem with my grandfathers ZX. It was a weld in the tank that had rusted through (through lack of use). I cleaned it up with a wire brush, used metal epoxy repair putty and when dry I repainted. Good as new.
Gill5oh
Oct 6, 2017 10:50 PM
NC14GT
Sep 10, 2017 04:47 PM
09-gt/cs
Oct 15, 2015 10:03 AM
mx5jhb
Sep 30, 2015 04:44 PM
Hristofor
1994-2004 V-6
Sep 11, 2015 12:05 PM
