computer transmission? tuner/shift kit or both?
Old Jul 9, 2014 | 07:45 PM
Antdroid23's Avatar
I was wondering if my 04 V6 mustang has a computer transmission? I believe the 05 does. I also wanted to know if i should get a tuner or a shift kit? Could I use both?
Old Jul 11, 2014 | 11:33 AM
zeroaviation's Avatar
Yes, different attributes about the transmission can be changed in the PCM. You do not have a "separate" computer just for the transmission. Well, not in the since you think of it.
Avoid shift kits unless your C4 or C6.
Cheers,
-Matt
Old Jul 17, 2014 | 08:30 PM
rodsoccer2's Avatar
Yes you do and it also has it's own separate wiring harness which is a good thing to think about if you were to swap to a higher power rated trans. Ran into wiring trouble when I switch from a t5 tremec to a pmphd 3650.
Road_Runner
Sep 2, 2024 04:46 PM
09-gt/cs
Oct 15, 2015 10:03 AM
GeoWett
Sep 30, 2015 06:40 AM
Sep 16, 2015 06:44 PM
