computer transmission? tuner/shift kit or both?
I was wondering if my 04 V6 mustang has a computer transmission? I believe the 05 does. I also wanted to know if i should get a tuner or a shift kit? Could I use both?
Yes, different attributes about the transmission can be changed in the PCM. You do not have a "separate" computer just for the transmission. Well, not in the since you think of it.
Avoid shift kits unless your C4 or C6. Cheers, -Matt |
Yes you do and it also has it's own separate wiring harness which is a good thing to think about if you were to swap to a higher power rated trans. Ran into wiring trouble when I switch from a t5 tremec to a pmphd 3650.
