Abs problem
Old Jun 27, 2013 | 08:55 PM
les's Avatar
les
Abs problem
I recently picked up a 2000 mustang. The other day I was turning into a parking stall on dry pavement and the abs kicked. Then the other day on wet pavement i was stopping but I wasn't sliding. Any ideas would be appreciated. It is the 3.8 liter with Trac control
Old Sep 27, 2013 | 10:56 AM
LivinTheStangLife's Avatar
Probably a bad sensor or a bad wire going to a sensor. Worked on a buick awhile back that kept kicking abs on at stops and it was a bad spot in the lf wire going to the sensor. Best bet is to check the abs for codes and check the sensor speeds with a scan tool to fins out which one is causing the problem
Rando
Aug 25, 2021 11:12 AM
Mpaps
Oct 11, 2017 08:06 PM
tukatz
Off-Topic Chatter
23
Oct 20, 2015 09:54 AM
09-gt/cs
Oct 15, 2015 10:03 AM
boz
Oct 1, 2015 04:47 PM
