trouble with hatch
Old May 30, 2012 | 10:11 AM
FOX50's Avatar
trouble with hatch
well ive got a 91 hatchback and the hatch is hard to shut and sometimes hitting bumps will cause the hatch to pop open.
anyone had this issue that could help me out on what could cause it?
Old May 30, 2012 | 10:21 AM
skunk21's Avatar
like I posted in your intro post you have to check the adjustment and you can also spray the lock mech with lube to see if it just sticking also. if you have to slam it hard to get it to hold then probally an adjustemnt will fix it. when I first got my current fox I had this problem ( most of the time when I would close it with the windows up, you push air into the car when closing the hatch ) once it was adjusted it was better. try this 1st, then you can move on.
Old May 31, 2012 | 07:02 AM
FOX50's Avatar
Do i just adjust the striker or do I have to adjust the actual hinges on the hatch
Old May 31, 2012 | 07:36 AM
skunk21's Avatar
striker & the rubber bumpers on each end need to be moved.
Old Jun 1, 2012 | 09:46 AM
FOX50's Avatar
Well i put some lub on latch it didnt solve the issue but im sure it helped with somethong tho, then i loosened my striker and mover it about an 1/8" to the passangerside and problem solved! I can shut the hatch so easily now its way easier like no effort needed!!
Old Jun 1, 2012 | 12:57 PM
skunk21's Avatar
Glad it worked. We try hard to help.
tukatz
Off-Topic Chatter
23
Oct 20, 2015 09:54 AM
mx5jhb
Sep 30, 2015 04:44 PM
PonyMuscletang13
Sep 29, 2015 09:40 AM
Airborne42
Sep 25, 2015 05:14 PM
14BlackGT
Off-Topic Chatter
Sep 10, 2015 12:13 PM
