Need advice for new rocker arms
Old Apr 13, 2013 | 10:30 PM
82 GT's Avatar
I'm having my '74 351w heads be converted to fully adjustable rockers. I told the machine shop that I would supply the parts (rockers, studs guides and seals).
I'm not sure what thread size to order for the studs or which seals to buy. Do I need 3/8 or 7/16 studs? I'm not sure what valve stem seals to buy because I need to know valve stem diameter. I know they were fitted with 1.94/1.60 valves a few years ago. I haven't ordered anything yet. I could have had him order the parts himself but I thought I might be able to get better prices online rather than pay his prices. Any help would be GREATLY appreciated!
In case you're wondering why I'm wasting time with stock heads , it's because I already have a lot of money into them from the last time I built my motor. The press in studs started pulling out so I'm having them done the way I should of had them to begin with...
Old Apr 14, 2013 | 12:05 AM
MustangFrontier's Avatar
Are these DOOE castings?
Old Apr 14, 2013 | 07:19 AM
82 GT's Avatar
Yes, I believe they are.
Old Apr 14, 2013 | 11:27 AM
The stock pressed in ones are 3/8 if thats any help.
Old Apr 14, 2013 | 11:28 AM
Also, how loose are the stockers? You could pin them in place.
Old Apr 14, 2013 | 02:46 PM
82 GT's Avatar
Yeah I could have them pinned but I think I'm going with screw in studs and 7/16 studs this time.
I'm going to go with roller rockers so I assume I need to get rockers that fit the same size stud? Any advice for what brand rockers to get? I'm thinking about either Comp Cams or Scorpions.
Old Apr 14, 2013 | 03:35 PM
Yes. The rockers have to match the stud. Comps are good. Have heard the scorpions are also. I use crane.
Old Apr 14, 2013 | 03:56 PM
82 GT's Avatar
Amother thing I am confused on is what is the difference between pedestal mount and stud mount rockers? I'm assuming I need stud mount...correct?
Old Apr 14, 2013 | 04:49 PM
Pedestal sits on the rocker boss basically, and a bolt goes through the top of rocker and bolts it to the boss, no stud is used. Stud is exactly what it sounds like, rocker has a nut that attaches it to the stud.
Old Apr 14, 2013 | 06:16 PM
82 GT's Avatar
So, I probably need to stud mount style, from what you described?
Old Apr 14, 2013 | 06:51 PM
If you have rocker studs, yes.
bones302
Oct 7, 2015 04:42 AM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
Airborne42
Sep 25, 2015 05:14 PM
GrabberBlue310
2012-2013 BOSS 302
Sep 17, 2015 08:21 AM
