If i go with this supension kit will i need caster/camber plates?
Old Oct 19, 2008 | 04:57 AM
touring's Avatar
http://www.latemodelrestoration.com/...0%201&comp=LRS
thanks
Old Oct 19, 2008 | 05:15 AM
Evil_Capri's Avatar
If you have a 4-cylinder, probably not. But if you have an 8 you may want to consider. I had KYB and FMS lowering springs on an old Capri 5.0 and did not have CC plates. I was planning on putting them on, but sold her before I purchased a set.
Old Oct 19, 2008 | 05:23 AM
touring's Avatar
So i should be good then, thanks for the reply
Old Oct 19, 2008 | 07:40 AM
Redbaron93's Avatar
If you can afford CC plates I would suggest going with them as they will allow more adjustment with your front end alignment
Old Oct 19, 2008 | 11:15 AM
touring's Avatar
which ones should i go with? preety much any one for my car?
Old Oct 19, 2008 | 11:32 AM
Redbaron93's Avatar
I went with BBK's for the 'vert. That's not to say they're the best but they were inexpensive and they work fine. Do some research and find which ones serve your needs best. If you're not going to be doing any road racing and just want a pair to give you more adjustment then the BBK's would be fine.
http://www.brothersperformance.com/c...products_id/90
Old Oct 20, 2008 | 05:07 PM
GT5088's Avatar
I have Maximum Motorsports CC plates, but that just my opinion. They seem to give the most adjustment compared to the other brands I have used in the past...
Road_Runner
Sep 2, 2024 04:46 PM
09-gt/cs
Oct 15, 2015 10:03 AM
GeoWett
Sep 30, 2015 06:40 AM
AJ_Trevino15
Sep 28, 2015 07:51 AM
MustangGTCS13
Sep 17, 2015 07:38 AM
