Drivers side door won't lock
As the question says I can't get my driver's side door to lock. The passenger side works fine. My door lock actuators work, I just replaced them. I still couldn't get it to lock with the lock actuators removed. I also replaced my door latch assembly. With the old assembly the lock would just pop back up when you pushed it down. Now with the new one it goes down, just not far enough. What gives?
It's an 86 GT with 115000 miles. Doors are lined up well and the hinge bushings and pins appear to have been recently replaced as have the strikers (I've only had it a month and have virtually no history other than my suspisions). I also have new lock cylinders, but it wouldn't lock with the old ones either. Although that did fix the passenger side locking problem.
Originally posted by Hotrod@June 23, 2005, 12:17 AM
Only thing I can think of would be taking the door panel off and seing if anything is interfering with the rod.
9/8/15 10:45 AM
