Notices
Any 306 running in the 11's N/A
Old 1/26/06, 11:19 PM
rja6214's Avatar
N/A only, if so list your combo
Old 1/28/06, 08:30 AM
MikeOxbig's Avatar
11's are pretty simple for a 5spd mustang w/ slicks, few bolt ons and some 6,000 rpm launches and it shouldn't be any trouble
11.7 @ 117 N/A, 10.90 @ 124 on nitrous
150,000 mile stock bottom end w/ E-cam 302cid
T-5, stock axles
26x11.5 ET streets
1992 Mustang GT, 2900lbs w/out driver
5SPD
1. Mystic Flames
2. Cervini Stalker Frt Bumper
3. 4" Cowl Hood
4. 3 Row Radiator
5. Electric Fan
6. Underdrive Pulleys
7. 125hp Nitrous Works Wet kit
8. Nitrous Purge solenoid
9. Edelbrock Performer Aluminum heads
10. Edelbrock Performer Intake
11. K&N airfilter
12. 73mm C&L Mass Air Flow Meter
13. 70mm Edelbrock Throttle Body
14. E303 Cam
15. New Headlights (3pc) w/ clear corners
16. Equal Length Headers
17. Off-road H-pipe
18. Flowmasters
19. King Cobra Clutch
20. 90/10 Lakewood Struts
21. 50/50 Lakewood shocks
22. Eibach Drag Launch springs w/ air bag
23. Subframe connectors
24. Aluminum Driveshaft
25. 3.73 Ford Racing gear
26. Weld Rod-Lites, 15x3.5 / 15x8
27. Mickey Thompson ET Street Drag Radials
28. Cobra Wing
29. Cobra rear bumper
30. 24lb injectors
31. Steeda Shifter
32. Rebuilt T-5 w/ Z kit
33. 255lph fuel pump
34. Adjustable clutch cable
35. Solid motor/trans mounts
actually driving it 45 minutes to the drag strip today, running on 275/50/15 ET Street Radials for the first time at the track.
Old 1/28/06, 09:22 AM
luvthe440Aroush's Avatar
beautiful car man, do you pull the wheels at all or almost get there?
Old 1/29/06, 10:19 AM
MikeOxbig's Avatar
thanks,
I'm not sure, it gets as close as possible
Old 1/29/06, 11:47 AM
conv_stang's Avatar
sweet ride man! thats smoking for bolt ons
RCooke08GT
2/19/17 03:03 AM
09-gt/cs
10/15/15 10:03 AM
10/2/15 01:00 PM
9/30/15 07:02 PM
Quick Reply: Any 306 running in the 11's N/A
