87 5.0 Engine pull. HELP
This is my first time ever pulling a engine out. I need to pull out my 5.0 engine off my 1987 mustang because the back freeze plug is leaking bad. I need tips and small tricks I can do to make this process a lot easier. I anybody can help me out with that I would really appreciate it.
Thanks,
Thanks,
Thanks,
Thanks,
This is the write up I'm going by.
It would take you a day, maybe. And you could pocket that $300. It's really not that hard. If you're not in a rush, I would do it yourself. Then, you have the experience! Me and other members would, of course, be there if you need us. :good:
I live in Sacramento California. And I would do it by myself but I work out of town all week and get the weekend off before I go back to work out of town Monday morning. So I like to just spend time with family. I don't mind doing little things but a whole day project take all my time away. If I have him pull engine all I want to do is change all freeze plugs and degrease the engine before putting it back in.
The freeze plug I need to replace is behing the engine block and everybody tells me I have to take engine out. Only way to fix it. And while its out why not replace all. Heads are good I think. Car runs just fine. Just leaks out that back freeze plug it looks really corroded. Leaks once in a while just want to get that fixed.
