Beeping
Old Apr 13, 2013 | 08:28 AM
MustangFrontier's Avatar
Beeping
So I have a couple foxes. A 93 vert and a 89 hatch. Every so often when start it the 93 will make a alarm clock beeping/ buzzing racket. The 89 has never done this. Anyone know what causing this?
Old Apr 13, 2013 | 03:41 PM
I think its the air bag module. Can any one confirm?
Old Apr 13, 2013 | 04:48 PM
Tyson30's Avatar
Mine does it also '93.. It's the airbag warning, if your light is out in your cluster you will get the buzzer and its relentless.. I just deal with the light!!!
Old Apr 13, 2013 | 04:54 PM
Tyson30's Avatar
Also u can check the two wire harnesses going to the module, make sure they have a good connection, mine started again after i hit a big hard bump... it's in a bad spot behind the heater/ac controls, it's like a green/blue color box with two plugs, there's also ur key/ door open chime under there also so don't confuse the two
Old Apr 13, 2013 | 05:29 PM
Thanks. Will check it out when get chance.
Old Apr 14, 2013 | 06:26 AM
Spaz's Avatar
Yes, upon startup the airbag warning chime will beep loudly 5 times, 5 times, 5 times. Most of the time my airbag light is on but this beep happens when the airbag light is malfuntioning.
PonyMuscletang13
Sep 26, 2015 02:33 PM
theredliner
2008-2009 BULLITT
136
Mar 24, 2008 12:17 PM
AircraftTech
2007-2009 Mustang GT/CS
Dec 5, 2007 03:11 PM
jfrayzier
Dec 14, 2005 02:17 PM
maddtrapper
05-09 Interior and Audio Mods
Apr 30, 2005 04:48 PM
