what will fit
Old Apr 13, 2005 | 09:28 PM
maddoxp's Avatar
I have a 66 mustang with a six cylinder and would like a v-8 don't know what will fit in there. are there any donor car's that i could use a engine and trans out of. looking for a cheap way of doing it.
Old Apr 13, 2005 | 10:39 PM
future9er24's Avatar
hmm and 289 or 302 (5.0) or 351W (5.8) out of a truck or mustang should fit. although a 351W may need a taller bonnet... not sure though.
the only V8s that wont fit are the clevleand, the 390/427/428 and the 429/460 adn all them biggn's. theres alot involved in a I6 to V8 swap.
IMO, the best thing to do is find yourself a wrecked fox 5.0 and take all the stuff u need, like the brakes n stuff to go with the engine, as well as the engine and trans.
good luck
Old Apr 13, 2005 | 11:32 PM
3RD1's Avatar
I put a 302 with twin Holly 4-barrels in mine. That was one nice ride.
Old Apr 18, 2005 | 02:46 AM
jgsmuzzy's Avatar
GOing to move this to the Classic section, there is a wealth of knowledge in there that can help you.
Blake, over to you!
Old Apr 18, 2005 | 07:34 AM
jpony645's Avatar
You're first order of business will have to be changing out the front and rear suspensions, brakes, etc. The 6 cylinder cars use different, much smaller components and won't support the weight or power of a V8 safely.
Read this: http://www.geocities.com/MotorCity/3...ecial/6to8.htm
It will give you a complete list of what needs to be done first.
As for engines, 289 & 302 will drop right in. 351W & 351C will fit with some minor modifications. Although the 351C is tight, it will fit without cutting the shock towers.
5.0 from a late model Mustang, Crown Vic, etc is also a nice replacement and will essentially drop in by using a carburetor instead of the fuel injection.
The front brakes from a Fox body WILL NOT fit early cars. They used a completely different front suspension set up.
The 8.8 rear will fit but will need to have leaf spring perches welded on and the housing may be a tad too wide. If you want to go this route then I'd suggest doing extensive research and measuring before diving in.
Old Apr 18, 2005 | 08:17 AM
copasspupil's Avatar
Josh is right on of this one. I would add that a 90-93 5.0 donor is the best. The guts of the engine are fantastic for higher hp due to its forged pistons, better crank and a roller cam. Not to mention that if it is a stick you want the T5 is a great choice. You need to keep in mind the bigger the block the heavier. Personally, I would stick to a 302, stroke it and SC if needed. It will be plenty fast
Also, with modifying the shock towers, any motor will fit. The engine bay dimension for a 65-70 are identical except for the shock tower widths.
Old Apr 18, 2005 | 12:01 PM
LMan's Avatar
bottom line, there is no "cheap" way to do this, at least by most folks definition of 'cheap', without serious safety compromises. Think carefully here.....
Old May 1, 2005 | 08:41 PM
67,GeArHeAd's Avatar
ihave a 67 6cyl
and i can fit either or
trackpack13gt
Jul 25, 2017 05:29 PM
mlcinema
Oct 7, 2015 10:05 AM
RoushRS3
Sep 29, 2015 08:03 PM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
