Motor mount ?
Originally posted by Stef 05 GT@May 17, 2005, 7:20 PM
Will 302 motor mounts fit a 351w in a 67 Mustang?
Thanks, Stephon
Thanks, Stephon
yes the mounts are the same. you will have issues if your using the origional frame mounts to put this motor into that '67. you have to use 68-70 frame mounts with 68-70 sbf mounts. if you are using the origional frame mounts with the 351w, you need to get the origional style 289 mounts SPECIFIC for a 67 with a 289. if the catalog of patrs place says 67-70, move on, go find the right mounts, because that place doesn't know mustangs well enough to sell parts to you.
so if you had a 302 in it, and still have the same mounts, reuse them for the 351w, no prob. if your trying to mix parts, make sure you have the right combonation of frame to motor mounts or you will have a headache!!
>>my opinion<<
