Converting from 2brl to 4brl set up
Old Mar 13, 2013 | 09:15 AM
les's Avatar
les
Hey guys real quick my mustang parts supplier has a date stamped 4 barrel intake and matching carb for the same year as my car so that I can stay original ish. So am I right for the conversion it's the carb, intake, riser, and fuel pump that need to be replaced for the conversion.
Old Mar 15, 2013 | 09:04 AM
les's Avatar
les
Buuuuummmmmpp
Old Mar 15, 2013 | 10:54 AM
BA Mustang's Avatar
You just need the intake and carb. If by riser you mean air filter, that housing is the same as well. Fuel pump doesn't need to be replaced.
Old Mar 15, 2013 | 02:21 PM
future9er24's Avatar
He might be talking about a carb spacer?
But yeah, you shouldn't need to change the fuel pump unless you're doing a good bit more to the motor.
HOSS429's Avatar
legacy Tms Member
i think the riser may be that about 1 inch thick plate between the carb and the intake that the PVC valve hooks to ...
Old Mar 15, 2013 | 02:23 PM
BA Mustang's Avatar
Yeah you are probably right.
I never had one on my 67, so I didn't think about that.
Old Mar 15, 2013 | 02:30 PM
The vacuumator.
Old Mar 16, 2013 | 12:41 AM
les's Avatar
les
Yes that is the part I am talking about the part between the two. Is there a large gain with an edelbrock low rise intake over the stock 4brl one? If so I may just hang onto my setup and but the edelbrock.
trackpack13gt
Jul 25, 2017 05:29 PM
yabutt
Oct 23, 2015 01:05 PM
Kalel08
Sep 29, 2015 03:06 PM
NC14GT
Sep 27, 2015 05:35 PM
