1970 Electrical Problems
Old Jun 26, 2007 | 04:07 PM
19seventy's Avatar
I cannot get my 1970 302, A/T started. Lights will not come on, no horn, no brake lights, etc. I've been thru all the routine stuff at some point recently - new battery, relay, battery cables, alternator loom, voltage regulator. Car is dead, but had been running fine prior to winter storage. Any and all thoughts appreciated.
Old Jun 27, 2007 | 05:32 AM
HOSS429's Avatar
legacy Tms Member
must have froze to death .. put a trickle charger on the battery and slowly build it back up ... sounds totally dead to me.... or do you mean you have done all the new stuff trying to get it to start .. sounds like a bad main fuseable link perhaps.. that`s the soft big red wire coming from the solenoid .. it feeds the inside of the car .. but even at that you should still have other things that work . unless the battery is stone dead ..
Old Jun 27, 2007 | 07:00 AM
Sharp's Avatar
Was the battery new after winter or before. A battery that froze can have a dead short in it and you won't even be able to jump it. Clip a test light to the chassis some where and start at the battery checking for power. Work your way to the fuse box and see if you can find where power stops at.
Old Jun 28, 2007 | 07:08 PM
19seventy's Avatar
Battery is not the culprit. The current battery in the car is only a week old and passes all the tests I have put it to. I have also tried 2 other batteries from operable vehicles with no success, so I can say with confidence that the problem is not with the battery. Does a fuseable link show any physical signs of failure?
Old Jun 28, 2007 | 07:14 PM
HOSS429's Avatar
legacy Tms Member
sometimes not .. pull on it and see if it breaks easily .. also there is the ignition switch that hangs on top of the steering collumn .. it can have a burnt wire that feeds everything .. you really should ask a mechanic for a quick look at it ..
Rando
Aug 25, 2021 11:12 AM
Mpaps
Oct 11, 2017 08:06 PM
09-gt/cs
Oct 15, 2015 10:03 AM
boz
Oct 1, 2015 04:47 PM
TerryD
Sep 28, 2015 11:48 AM
