Transmission Fluid Temperature Scan Tool / 5R55S Service Info
Team,
Seeking recommendations for a reliable transmission fluid temperature scan tool. The reviews on a few of them on Amazon are scary...so I turn to my friends here for input. I am all ears...
Updated Title For Future Searchability!
Kc Admin
Kc Admin
Any Other Members With Some Knowledge on This Feel Free To Chime in as Well!
Kc
What are you working on? My Launch Scanner will read transmission temperature provided the vehicle has a sensor in it. The 15 and newer Mustangs actually have a gauge you can toggle to for the info. But my scanner is $6000 so unfortunately I don't have any input on any of the cheaper amazone ones. I haven't had a lot of need for that feature on my end, what is going on?
I want to swap out the gasket that is leaking -- or so I think, and by the way change the fluid and filter. 2006 Mustang GT Auto Trans has no dip stick and Ford has a clunky way procedure to do this right. Part of it involves knowing the trans temp. Unless.....I am wrong...which it would not surprise me at all...
Gotcha I'm Looking At Process Now. Perhaps The FORD WDS Setup Has Some Way of Getting The Temp. I Wonder if a Temp Gun Pointed at One of The Cooler Trans Lines Would Be Close Enough!
I'm Going To Give You Some Shop Manual Pdf's For Reference. I Would Surmise There are Some Alternatives To How FORD Does It But Checking Out The Factory Specs Should be Useful!
KC, those .pdf are spot on what I am looking at doing. Once again, you have saved me from doing tons of research on this task....my friend, hats off to you...much appreciated.
Gotta Keep This Library Open!
You Are Quite Welcome! Let Us Know The Tricks After You Do The Hands On!
I Just Remembered This Thread Worth a Look!
https://themustangsource.com/forums/...ptions-551012/
KC, thanks for the links to the Trickflow...I remember seeing that sometime ago. Dumb question...do I have the 5R55S transmission? My VIN is: 1ZVHT85H665238144
Not a Dumb Question at All! There are So Many Variations of Things It Pays To Be Sure. As Per Ford Yours is Listed as 5R55S. Many Times I'm Sure of Things Until I get Asked The Direct Question and Then HMMM I Better Be Sure!
Ford Database
VEHICLE DESCRIPTION:2006 Mustang
VERSION/SERIES:GT VERSION - CAR
PAINT COLOR:Ebony Solid C/C
BODY STYLE:Convertible
DRIVE TYPE:2 WHL L/H REAR DRIVE
PAINT CODE:UA
ENGINE:4.6L 3v V8 SOHC EFI
AXLE RATIO:3.31 Ratio
GROSS VEHICLE WEIGHT:4550 LB. GVWR
ENGINE CALIBRATION:6ZF1G80A
AXLE CODE:CG
RADIO:CDX6+ With Speed Sensor Vol Control.
TRANSMISSION:5 Speed Auto Transmission 5R55S
WHEEL SIZE:17 X 8" Painted Alum W/Mach Rim
FUEL TYPE:Gasoline
TIRE:P235/55ZR17 99W A/S
Sold to Fleet:NO
Retail sales type:R
Ford Database
PAINT CODE:UA
AXLE CODE:CG
FUEL TYPE:Gasoline
Sold to Fleet:NO
Retail sales type:R
https://www.amazon.com/dp/B0CNJM36JL...uRaFrSHpB0M79w
I have always hated that manufacturers have done away with the dipstick tubes. I think it's partly to try to force the DIY guys to go to the dealerships. When they did this it forced me to spend a lot of money on specialized tools to fill the transmissions. As a note and thinking back I haven't had to service any Automatics in the S197s but other Fords when missing the dipstick actually DO still have a dipstick but its very tiny on the end of the cap at the transmission and they want you to measure the level when hot while running...which is a royal pain on some vehicles while you trying not to burn yourself on a catalytic converter! I did a transmission in a Ford Raptor and it had the tiny dipstick but in a Lincoln Aviator the process was using the special tool I had to buy to fill the transmission through a fitting in the bottom of the pan, it had no dipstick.
A pyrometer will get you close enough to the temperature if you aim it at a transmission cooler line...compare the too and use the hotter temp because the cooler temp would be the return line from the transmission cooler and wouldn't be as accurate a reading.
Thanks Paul!
Good Tip On Hose Temp Hot vs Cold!
This Brought To Memory Those **** Lifetime Air Filters on The Early Ford Focus! A Little Reading And Of Course it Had To Do With **** PZEV Regs. I Had No Idea, Thanks Big Brother! While Not Directly Related To Dipstick Issue it's Still Bred By The Govt. Mucking Things Up! An Interesting FYI Short Read!
If I Had One of Those Cars Back in The Day or Mustangs Had Them a Retrofit Would Have Been a Mission For Me! Funny My 02 Supercharged Harley F-150 Is Considered PZEV Go Figure! The More They Make Things Hard To Do The More Creative Those Select Few With The Hot Rodding Spirit Find a Way Around. The Masses Just Pay The Bill. A Lot of That Going on in Everything these Days!
The Aftermarket Did Come To The Rescue on These in Time Thankfully.
https://www.underhoodservice.com/lif...fad-or-future/
Just wait....one of the disadvantages of pushing everyone into EV's is that they can just shut them off remotely. If the Gov't deems a pandemic and doesn't want you to travel, just turn them off. As you can imagine the overreach could be significant. So keeping that old '66 Mustang around is sounding more and more like a great idea!
05stangkc (8/24/24)
05stangkc (8/24/24)
KC,
Need your help. I am having a heck of a time finding the right crush washer or whatever type that is for the transmission fluid pan bolt which I think is Ford 6R3Z-7A010-A Pipe - Oil Drain (for the bolt). Here's a pic of what is there now (greenish washer). Everywhere I search, I can find the drain plug(bolt), not the wahser. Local part store (autozone, advance auto cant find it). Please let me know what say ye?
