2005-2009 Mustang Interior Door Trim Panel Repair Threads
Received 2,861 Likes
@SpaceCadet
Saw You Searching Terri! Welcome Back!
A Good Sampling of The Door Panel Insert Issue Repair Topics.
I Like the First One Only Thing I Would add is After The Rolling Off of the Dried Up Foam I Would Go Over With a Cotton Ball with Denatured Alcohol on Both Door Panel & Upholstory Panel. I Would Also Let Dry Overnight before Using Adhesive. Also I Found it Much Easier To Work With The Panel Removed From Door! I Was Fortunate with My Shelby I Never Used Any Trim Chemicals on My Panels So I Did Not Have to Contend with a Silicone or Whatever Chemical Making the Bond More Difficult. It Took Three Times To Get it Figured Out. The Sprays Would Not Work. I Did Not Use The Contact Cement as Shown But Used Gorilla All Purpose Glue and a Lot of Rubber Gloved Massaging into The Panel.
Here is Another Tip. If You get a Pesky Air Bubble Stick a Needle in a Few Perforation Holes to add a Vent.In The Event any Glue Comes Through, Unlikely Unless you Really Slathered it on have Some Denatured Alcohol & a Cotton Ball or Terri Cloth on Stand By. Works For Adhesive on Door Panel as Well if You get Right on It! Worked for Me!
Read Em All & Choose Your Own Path!
BTMO
https://mustangforums.com/forum/2005...gging-fix.html
https://themustangsource.com/forums/...5-09-a-485487/
https://themustangsource.com/forums/...-panels-550817
https://themustangsource.com/forums/...g-help-477951/
https://themustangsource.com/forums/...-panel-545347/
https://themustangsource.com/forums/...rt-fix-511679/
BTMO
69CaliStang (5/15/24)
Nice find! After reading over the thread links posted, I found the Weldwood contact cement method and upholstery shop method with tweed material as the most effective options IMHO,
The following 2 users liked this post by 69CaliStang:
05stangkc (5/15/24),
m05fastbackGT (5/15/24)
I'm still debating on whether to reapply the OEM vinyl insert panel or go the Coverlay ABS plastic insert replacement instead...
https://www.coverlaymfg.com/series-8...odel%3DMUSTANG
They did, but only if you opted for the deluxe, non-premium package... Had I known about the vinyl inserts peeling off prior to purchasing the 2005-09 premium options, I would've gone with the deluxe option instead.
Ironically The Other Leather Package With the Console Lid & Stitched Dash Held Up Just Fine! Also Upgraded Door Armrests! Funny Thing This Package Never Shows Up in KBB. At Least Not Last Time I Looked! Gotta Be Worth Something!
I Know I Have It! So Few Options Available I Had To Get All I Could!
Sold The Heck out Of the Console Lids Back in The Day!
GT 500 Premium Interior Trim Package (incl.
wrapped & stitched instrument panel brow & center
console w/upgraded door armrest, electrochromic
rearview mirror w/compass & aluminum pedals.
PACKAGE 68S
PACKAGE 68S
m05fastbackGT (5/20/24)
When Choosing Inserts Get Some Good Ones as Cheap Crappy Ones Will Go Bad Just Like Original Insert! Go For Brand Name! Coverlay is Likely a Good Item! Especially in Very COLD or VERY Hot Area's!
Kc
Kc
Predator Mustang inserts are even better... Question is whether they're still in business or not? Here's 5 YouTube videos from a few years ago...
rocknrod (7/12/24)
I went with Dashskin Door Panel Inserts
Thanks For The Real Worlds Experience!
I Recall your Name From Back in The Day!
Looks Like Your Last Post Was in 2015 Have You Been Visiting Without Posting are is This a First Return??
Upgraded Your Title & Would Love To Have You Update us in REINTRODUCTIONS! You Can See The Old Timers still Here!
https://themustangsource.com/forums/...embers-550106/
Welcome!
Kc
Welcome!
Kc
Back in THE Day on My 05 I Added Ponies To Brighten Up & Emulate 69 Door Panels!
Digital_Synapse
'10-14 Interior and Audio
13
10/6/10 10:29 PM
