Driveshaft bracket has broken
Hello everyone and thanks for reading and giving me any helpful info.
This is for a 2007 mustang GT 5speed manual 4.6L v8 with 90k miles.
so long story short. I was driving home from work and I hit a really bad pothole on the expressway. It sounded like something really loud hit under my car. When I got off my exit it sounded like and felt like there was a basketball dribbling under my ebrake lever. And when I would take off and drive it would stop, until I hit brakes or slowed down and again this obnoxious sound by my ebrake lever returned. After getting home and jacking car up, I was able to find the problem. The driveshaft bracket that holds the driveshaft up is missing a bolt on one side and is dangling and on other side it looks to be messed up longer and it’s bolt is there but the bracket is bent and broken on both sides of that bolt that is suppose to hold it secure to the car. I will post pictures to show but it was very difficult to get pics and probably even more difficult for you all to understand what I’m meaning. My question is…how can I just buy and replace that bracket and bolt. I can only find the safety loop system for the driveshaft, which is not the same but as far as I know it can be used along with this broken bracket… I have searched the internet high and low and am unable to find just that part! Please anyone that can help I will be forever thankful for!! Thanks in advance and for anyone who suffered through this reading. : /
2007 mustang gt. Help me. Broken bracket on driveshaft. And missing bolt!!
Received 2,620 Likes
HERE YOU GO!
BE ADVISED I LOOKED UP PARTS WITHOUT VIN. SOME WOULD NEED TO BE DOUBLE CHECKED WITH VIN!
https://www.americanmuscle.com/frpp-...ft-0510gt.html
How to Install!
This replacement Driveshaft will Eliminate That Carrier Bearing & Bracket.
I know it's a Hard Hit. Please Read all about it!
Cj's
https://www.cjponyparts.com/ford-per...0/p/M4602MGTA/
Rock Auto See Dorman
https://www.rockauto.com/en/catalog/...ive+shaft,2308
The Front Section From Ford Is More Than a one Piece. I would Bet Carrier Bearing is Bad in Yours!
https://www.fordpartsgiant.com/parts...39430;7130;871)
Also You Might Check Locally for a Driveshaft Repair Company.
Other Members May also Have Some Suggestions As Well!
How to Install!
Cj's
Cj's
The Front Section From Ford Is More Than a one Piece. I would Bet Carrier Bering is Bad in Yours!
https://www.fordpartsgiant.com/parts...er=(39430;7130)
Cj's
I was afraid of this…Im a single mother of 2 boys and can not afford to buy a brand new driveshaft.
What is Your ZIP Code I will Find Used???
LKQ
https://www.lkqonline.com/2007-ford-...D/-i~305168758
PICKINGS ARE SLIM ON OEM STYLE. CHECK FOR LOCAL DRIVESHAFT COMPANY OR LOCAL WRECKING YARD.
OK, You Can Go Used! But I fear those Bolts Will Need to Be Extracted. You Want to Find Lowest Miles car You Can! Local Yard LKQ Parts and Ebay!
Looks Like LKQ is Only Listing REAR of TWO PIECE STYLE so you would have to Call!
I WILL POKE AROUND SOMEMORE. MIGHT AS WELL GIVE ME YOUR VIN AS WELL!
Post and Go Relax This May Take a Little Time. I was a Ford Parts Manager 30+ Years in Ford Parts!
I'm Doing the Best I Can! But if Anybody Else Has Direct Experience on Repairing These or Other Idea's Chime in!
Here is a Mustang Only Wrecking Yard For Reference!
https://prestigemustang.com/
How To Driveshaft Topic!
https://themustangsource.com/forums/...w-pics-455739/
Ok, Looking At the Driveshaft From What I Can See and You Say You Hit a Pothole. It Is Possible You Simply Broke the Center carrier Bearing Retainer and One Of the Bolts. If and I Mean If the Carrier Bearing is Good You May get Away with Drilling Out and Extracting Broken Bolt.
Finding a Used Bracket & Attaching Bolts And Reinstalling I don't Know If The Repair Can Be Done With Driveshaft Still Installed or Not. So If Everything is Ok Less Bracket & Bolts This Would be The Cheapest Way to go.
Update
Looking at the Pics Of the Strap is Does Not Look Very Promising I think is a 2 Piece That is Spot Welded Together. Understandable as if It came Off Results Would Not Be Good! So Now Looks More Complicated Still Looking at Options.
Btw, Great Pics and Explanation and Also Including enough Information to Figure Out. Believe Me We Get Minimal Info Many Times When Folks are Looking For Help. Kudo's to You.
Ok, So Local Driveshaft Shop or Wrecking Yard May Have What you need. Also with So many Going the One Piece Route Maybe Somebody Out there Has Some Parts Laying Around! Hint Hint!
I have Posted Two How To's & a Ford Shop Manual PDF to Help Whoever Tackles This.
Kc
Members, If I'm Missing or Forgetting Anything Chime in!
UPDATED
Update
Kc
UPDATED
https://www.lkqonline.com/2007-ford-...ar/-hjP3OncjPD
Here Are Kentucky LKQ Listings I would Call & Verify They are Selling you Both Pieces of A Two Piece Driveline!
I would Guess They are Already Pulled But If Not You Could Ask for Bolts.
Seems Too Cheap! Pick Lowest Mileage You Can Find
Kc
I believe these are the Bolts.
Shows to be 10x30mm. Since they Would Charge you Shipping I Would
Go To Local Ford Dealer and Ask For Driveshaft Carrier Bolts.
And Carrier Spacer. They Will Likely Sell you a Pkg of 4 If they Do Not Stock them!
You At Least Need 2 Bolts & 1 Spacer
https://www.fordpartsgiant.com/parts...xle_drive,,HB1
Spacer
https://www.fordpartsgiant.com/parts...xle_drive,,HW1
You Need HB1 & HW1 As Shown Here.
https://parts.ford.com/shop/en/us/ha...300759-1?pdp=y
Kc
Ford -W506434-S439
BoltFord -W710432-S300
Spacerhttps://www.fordpartsgiant.com/parts...xle_drive,,HB1
Spacer
That's My Best Shot. You Can Call Local Wrecking Yards. LKQ is a Hard Price to Beat. All Lkq is are Wrecking Yards That List their Items in a Collective Database! Still Gonna Have to Drill Out Bolt Unless it Just Fell out. I doubt it!
The Lowest Price New is Just Under $500.00 At Rock Auto. With That One No Carrier Bolts or Bolt Extraction.
Ford Likes to Replace Bolts on Any R&R but if Bolts Are in Good Shape & Cleaned & Use LokTite you should be Ok! Speaking of Front & Rear of Driveshaft Bolts!
Any Questions??
Any Questions??
Any Questions??
Any Questions??
Basically a Thick Washer. It's Got to Be Gone.
Watch & Read Install Info I Posted and You Will Be an Expert in no Time!
I learned a Lot Myself Today! Take Care of those Boys!
Take Care!
I got to Thinking Your Insurance May Cover Pothole Damage!
https://www.progressive.com/answers/...othole-damage/
I know. Super old post but wanted to say Thanks to you boss for all this great Info. Currently need a new drive shaft as well. Looking for a used 2 piece or spend the money for a 1 piece... Humm.
Bert (5/10/24)
Received 1,509 Likes
I think there was a thread recently about replacing that center carrier bearing, you might want to take a look at that, if it is only the center bracket that is the problem
VGMStudios (5/11/24)
I tossed mine in the crapper and got a 1 piece Aluminum one. Installed easily and it has worked great! The only thing I didn't like was the "hex" pattern bolts going to the differential - they were very hard to torque. Bonus in the included new Spicer U-joints.
3.5" Mustang Aluminum Driveshafts for Transmission or Rear Axle swap Applications (shaftmasters.com)
Installed December 2017.
3.5" Aluminum Driveshaft FMS0510GT35D-1350 1 649.99
Ford Mustang 2005-2010 V8
GT Direct Bolt-In
Subtotal 649.99
Shipping 0.00
Tax 0.00
Total 649.99
GT Direct Bolt-In
Subtotal 649.99
Shipping 0.00
Tax 0.00
Total 649.99
TacoBill
GT Performance Mods
85
10/2/12 10:05 AM
