1974-1978 Mustang II Member Tech & Restoration Discussion
explorer 5.0 fan on my 302?
Old Dec 7, 2007 | 01:17 PM
future9er24's Avatar
Question explorer 5.0 fan on my 302?
Just recently I was told by my mechanic that there were two thigns contributing to my car's running hot: the water pump was going, and my mechanical fan was for a 2.3L (go figure)
So what I want to know is will this fan out of a latemodel V8 explorer fit in my II? the motor in my II is a 1992 5.0. Additionally, is there any actual benefit to this fan? It looks pretty monstrous and seems like it would flow better, but i dont know for sure. If theres no real benefit to this, or if it doesn't fit, what do you all recommend? I think it probably will fit, but I'd like to ask some of you smarter folk first before I make the plunge...
http://cgi.ebay.com/ebaymotors/Ford-...QQcmdZViewItem
Also, on the topic of water pumps, how much better is a $70 Edelbrock one compared to a Ford part, or even one of the cheaper $20ish ones on eBay? I'm willing to spend money where I need to, but id I don't need to, hey thats some saved cash
generic pump vs Edelbrock pump
I'd really like to get my II to run reliably in the near future so I can focus on updating the rest of it. Thanks in advance!
Old Dec 8, 2007 | 07:36 PM
Old Dec 9, 2007 | 10:30 AM
hi5.0's Avatar
Some things to check - make sure your charging system (alternator) can handle the demand of the fan's motor, check clearance of fan motor to waterpump pulley and other engine accessories, and have a provision to mount the coolant overflow tank because it may not fit in the stock location with the new fan.
As for the water pump... a stock replacement should be fine or maybe one of the lower cost units from Summit "flowkooler?" or an equivalent although $70 for an Edelbrock unit is pretty good.
IMO, a electric fan from a 3.8 V6 Taurus works well for a lot of Fox 5.0 electric fan conversions, the MkVIII is probably overkill - for the electrical system anyway. A known reliable electric fan controller is the one from Delta Current Control. Seems the site is back up, but you may have to wait at least a month before your order goes through - a lot of people swear by them and that's the route I would have gone... another one would be the FAL variable speed fan controller PN# 33054 which can handle the Taurus fan, but not the MkVIII. Or just use a relay and a manual on/off switch. =)
Old Dec 9, 2007 | 12:59 PM
Well I'm not looking at electical fans, just mechanical. If I ever do go the electric route, you can be assured I will be using a Taurus fan, I've heard tons of great things about them.
I already bid on another Flex fan straigh out of a fox, so I'm no longer concerned about finding a fan.
As for the water pump, I havent ordered one yet, but I'm content with the findings on eBay. Thanks!
Road_Runner
Sep 2, 2024 04:46 PM
Infamous_blackbeard
Oct 8, 2015 10:45 PM
boz
Oct 1, 2015 04:47 PM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
