Ecoboost
Purge valve stuck open on 2016 eco
Old 9/5/16, 07:58 AM
stangchief's Avatar
Check engine light came on and dealership shows purge valve is stuck open....they have to order the part.....have no symptoms whatsover....does anyone have an opinion as to whether there is a problem continuing to drive it until repaired?
Old 9/5/16, 08:56 AM
MAD70601's Avatar
In my opinion, they wouldn't have let you leave the dealership with the car if it was a problem.
Old 9/5/16, 11:54 AM
stangchief's Avatar
Update.....left the dealership and light has been reset by technician. Does the fact that the light has not come back on indicate that the valve is now not stuck open or could it still be stuck and the light just not showing since the code was reset?
Old 9/5/16, 06:41 PM
SpectreH's Avatar
Received 1,155 Likes on 843 Posts
Some faults require a minimum amount of time in fault mode to throw a code. I don't know if the BOV is one of them and just hasn't set it again or if it is truly unstuck.
Old 9/5/16, 07:12 PM
stangchief's Avatar
Tech said it was code po1450
Old 9/5/16, 08:43 PM
SpectreH's Avatar
I don't know if it trips instantly or needs time. Seems like a stuck open BOV would just keep you from building boost like you should.
glo106
10/9/23 04:59 PM
FireRescue42
9/26/16 12:20 PM
stangchief
Ecoboost
9/4/16 08:10 AM
Gigantor
8/13/16 09:34 PM
Quick Reply: Purge valve stuck open on 2016 eco
