Ecoboost
Purge valve stuck open on 2016 eco
Old Sep 5, 2016 | 07:58 AM
stangchief's Avatar
Check engine light came on and dealership shows purge valve is stuck open....they have to order the part.....have no symptoms whatsover....does anyone have an opinion as to whether there is a problem continuing to drive it until repaired?
Old Sep 5, 2016 | 08:56 AM
MAD70601's Avatar
In my opinion, they wouldn't have let you leave the dealership with the car if it was a problem.
Old Sep 5, 2016 | 11:54 AM
stangchief's Avatar
Update.....left the dealership and light has been reset by technician. Does the fact that the light has not come back on indicate that the valve is now not stuck open or could it still be stuck and the light just not showing since the code was reset?
Old Sep 5, 2016 | 06:41 PM
SpectreH's Avatar
Some faults require a minimum amount of time in fault mode to throw a code. I don't know if the BOV is one of them and just hasn't set it again or if it is truly unstuck.
Old Sep 5, 2016 | 07:12 PM
stangchief's Avatar
Tech said it was code po1450
Old Sep 5, 2016 | 08:43 PM
SpectreH's Avatar
I don't know if it trips instantly or needs time. Seems like a stuck open BOV would just keep you from building boost like you should.
glo106
Oct 9, 2023 04:59 PM
FireRescue42
Sep 26, 2016 12:20 PM
stangchief
Ecoboost
Sep 4, 2016 08:10 AM
Diode Dynamics
Sep 2, 2016 10:38 AM
Gigantor
Aug 13, 2016 09:34 PM
