2019 Bullitt wheels on ‘14 Brembo car?
![Question](https://themustangsource.com/forums/images/icons/icon5.gif)
So the 2019 Bullitt car has brembo brakes, and from the pics I’ve seen - come with Ford 5 spoke wheels.
The 2019 wheel specs are:
19 x 9.5
52.5mm offset
5-114.3 bolt pattern
70.5 bore hub
https://www.detroitwheelandtire.com/...10222-mbb-a-r/
this factory pic
https://www.nydailynews.com/autos/bl...lide=1.4041982
will it fit my 2014 GT with the brembo package?
TIA
19 x 9.5
52.5mm offset
70.5 bore hub
this factory pic
TIA
According to the Detroit Wheel site, my stock wheels are:
19 x 9
42mm offset
70.5 bore hub
so help me figure out the offset please
I currently have these:
https://www.detroitwheelandtire.com/...-hshshs-a.html
19 x 9
42mm offset
70.5 bore hub
Received 1,547 Likes
hi, I know I'm a little late to respond . . . my understanding is that yes S550 wheels will go on S197 cars, but:
1) the offset is a little less on the S550, so they may stick out of the wheel wells on the S197
2) the lugs are different, so you'll need to use your old S197 lugs (S550 lugs won't fit)
3) the bore is larger on the S550; this means they will go on but will not bore center (not positive about this one)
4) the TPMS system is different; S550 tire pressure monitor sensor will not work on S197 car
so generally I recommend that you stick with S197 wheels for S197 cars, but it would be cool to have a Bullitt wheel that would clear the Brembo brakes
