Tire and Wheel Tech All the tire and wheel technical information you can think of in one place!
Will 235 65 R18’s fit on my stock 2009 gt?
Old Dec 2, 2019 | 08:24 PM
dylantanderson's Avatar
Will 235 65 R18’s fit on my stock 2009 gt? Just finding some snow tires and trying to figure out what’s the biggest I can go.
Old Dec 3, 2019 | 08:50 AM
Bert's Avatar
I think they will probably fit but they will be significantly bigger diameter than the original tires.
Best way to figure this out is to look up your original tires on Tire Rack (or any other place that has the specs and information) and look on the "specs" tab to find the diameter of the original tires. Then look up the new tires you are considering, and check the diameter of those (while your at it also check the recommended rim width). You want the new tires to be no more than about 1" larger than the old ones, and there should be plenty of clearance because Ford still designs with enough clearance for snow chains.
Old Dec 3, 2019 | 10:31 PM
GrnT's Avatar
I have all season 265/45r18 on mine.
Old Feb 18, 2020 | 06:54 AM
David Young's Avatar
If you have 235/50-18 and go to 235/65-18 my tire size chart says it would be dangerous. At 60 mph you would really be doing 66.1 mph with the larger tires.
2004GTMidnight
May 4, 2013 06:51 PM
stang23456
1994-2004 V-8
Oct 16, 2009 10:42 PM
LordBritish
Feb 5, 2008 10:57 AM
superman112
05-09 Exterior Modifications
May 6, 2006 08:34 AM
MINO4.6
Oct 25, 2005 10:36 AM
