TPMS????
Old Oct 25, 2013 | 02:49 PM
numnutz's Avatar
TPMS????
Does anyone know if the TPMS system on 2012 can be disabled, bypassed or what? Not knowing that car had this, I put a set of wheels on it with regular valve stems (DUHHH!!!!) and now have choice of breaking down original and putting them in new wheels or buying another set of sensors, neither of which is very appealing. My mama said my middle name was stoopid, but I thought she just favored me. Thanks.
Old Oct 26, 2013 | 10:32 PM
ARBO's Avatar
If you decide you want a set of TPMS's I have a set off a 2012 in for sale section. FYI
Old Oct 27, 2013 | 08:38 AM
Ltngdrvr's Avatar
The car will run and drive totally normally without the TPMS sensors, you will just get the dash warning.
No way to disable it as far as I know.
Old Oct 27, 2013 | 08:45 AM
ion_arch's Avatar
how much is it? Are those oem? Are those work on 2013 v6? Thanks
Old Oct 27, 2013 | 09:50 AM
Getportfolio's Avatar
Tpms sensors are pricey. 80-150. You need the relearn tool or take it to your tire shop to flash once installed.
Open to debate because of shelf life: however, I purchased my OEM set on eBay for 75 bucks 2 years ago and they are going strong.
Old Oct 27, 2013 | 09:52 AM
Tpms sensors are pricey. 80-150. You need the relearn tool or take it to your tire shop to flash once installed. Open to debate because of shelf life: however, I purchased my OEM set on eBay for 75 bucks 2 years ago and they are going strong.
Note several sets on eBay from trusted sellers for 60 bucks flat.
Old Oct 27, 2013 | 12:21 PM
ARBO's Avatar
Yes my are OEM off a 2012 that were on the car for 600 miles, like new. Yes tire store will have to pair them up to your car. If u can get them cheaper have at it. Check my rating here and (eBay as usarbo). I do see them on ebay for $60, say will work on Mustang. Have at them. $100 min from me. Price mentioned above from dealer$80-150 is for each sensor.
Old Oct 27, 2013 | 01:06 PM
Ltngdrvr's Avatar
You will also need to replace the valve stems as well if the ones that were used weren't for stem mounted TPMS.
Old Oct 27, 2013 | 02:48 PM
ARBO's Avatar
Correct, that's exactly what it says to do on the sensor. Each time it is dismounted. That's the correct way to do it anyway. Read the info on the round part.
Old Oct 28, 2013 | 03:02 PM
numnutz's Avatar
tpms
Thanks for all the help. Got a set from DETROITAUTOPARTSGALORE for 60 bucks. Mashed 4way flasher button 5 times and synchronized all 4 within 5 minutes. Thanks again.
Old Oct 28, 2013 | 03:59 PM
ARBO's Avatar
That sure is a good price. OEM from Ford they are $85 ea, I just called. Good find!
Old Jan 5, 2014 | 10:48 PM
ARBO's Avatar
Bump for winter tires.
trackpack13gt
Jul 25, 2017 05:29 PM
trackpack13gt
Jul 23, 2015 11:13 PM
