Staggered setup
Old Mar 28, 2022 | 07:39 AM
Sicarius's Avatar
Staggered setup
Heya guys! I'm having issues picking the size for my staggered setup. I have 19x9.5 front and 19x10.5 rear. I think I might go with 255 front and 295 rear but im not sure pros and cons and what wall size should I go? Some people told me 40 front and 35 rear but Im not sure whats the reason the rear should be lower? Im at stock car height.
Old Mar 28, 2022 | 02:54 PM
Bert's Avatar
You want the overall diameter of the tires to be about the same front and back, and also about the same as the original tires . . . that is the reason for the different "aspect ratio" for the front and rear. The 35 or 40 number is the "aspect ratio" which is the sidewall height as a percentage of the tread width. You need a lower aspect ratio with a wider tire, to get the same sidewall height.
Check your original tire size in the door jam sticker; then look up that size and note the overall tire diameter. On most of these Mustangs it is 27.2"
Next look up the new tire size on Tire Rack (or anywhere that has the information) and check the diameter. Play with the sizes until the front and back are close to the same, and also close to the original.
295/35-19 for the rear and 255/40-19 for the front seems like a good set-up; both are 27.1" diameter, and pretty well matched to those wheel widths.
Old Mar 28, 2022 | 02:57 PM
Sicarius's Avatar
Thank you! I will be going for that setup!
Old Mar 28, 2022 | 03:24 PM
Siber Express's Avatar
Mine is 255/40 19 and 295/35 19
Old Mar 28, 2022 | 03:29 PM
Sicarius's Avatar
Yeah, you were the one to tell me about that size on 3.7 fb group, had to get a second opinion and I guess im going with that setup 😁
06GTwJUICE
56
Jun 16, 2025 02:49 PM
toneofjustice
33
Apr 26, 2017 09:58 PM
colbymh
05-09 Exterior Modifications
54
Oct 15, 2010 06:41 AM
WuTimeUT
19
Dec 20, 2007 10:20 AM
YaoNYC
Aug 29, 2007 05:39 PM
