SR Springs on a '14 V6. Do I really need GT500 Strut Mounts?
*noob alert*
as advertised on AM, they say i need gt500 strut mounts and matching dampers to install SR springs on a '14 V6. http://www.americanmuscle.com/sr-springs-0513gt.html
i ask, why?
i ask, why?
*noob alert*
i ask, why?
i ask, why?
As for the GT500 strut mount, Ford changed the front strut mount and strut shaft-end design for the 2011-14 Mustang, rendering any shock made for the 05-10 Mustang incompatible with the 11-14 strut mount, requiring the new mounts.
- GT500 strut mount - works on 05-14 Mustangs
- 05-10 struts have different shaft-ends than 11-14 struts
- 11-14 strut mounts are incompatible with 05-10 strut mounts
- 05-10 struts can be installed on 11-14 cars with the GT500 mounts
- There is no difference in the aftermarket struts for 11-14 cars other than the shaft ends.
- There are some aftermarket dampers available specifically for 11-14 cars = no strut mount change
Former Vendor
*noob alert*
i ask, why?
i ask, why?
If you have any questions, feel free to give my CS team a call! They'd be happy to answer any questions you may have. Our Mustang Experts are here Monday-Friday from 9AM-9PM EST and Saturdays from 9AM-5:30PM EST. If you want to hit them up, their number is 866.727.1266.
-Dan
I would check to see if the mounts will work with the stock shocks. I had also read that with lowering springs they recommend the GT500 mounts, so I bought them, and then was unable to put them on my shocks because the shaft was too big.
People usually find that when they install lowering springs, the ride goes to crap since the OEM dampers (struts/shocks) cannot control the stiffer and shorter ride height very well, thus requiring a change in dampers.
This is exactly the information the OP needs!
Just installed on '13 V6
I just installed a set of SR springs on my 2013 V6. The ride height is perfect! It dropped my stang 1.5 inch in the front and 1.8inches in the back. You do notice all of the bumps and the stiffness.
After a week of settling in, I ordered the camber bolts and had her aligned this morning! I am very very happy with my purchase. IMO: it is the best looking ride height.
I will be purchasing adjustable Koni shocks and struts to accompany these springs. THANKS AM!
I also installed an adjustable pan bar from JM. The drop offset the rearend a 1/4 inch. The panbar corrects this.
I also have an upper strut bar from Whiteline which may help.
Good luck! hope this helps.
CVH
CVH
Update to my previous post: After the struts and shocks blew out, the ride became horrible. I just installed the 2011 GT500 mounts and a set of Konis STR.T struts and shocks.
Major improvement.
Major improvement.
robjh22
9/8/15 12:31 PM
