SR Performance Lowering Springs
Old Jul 24, 2014 | 07:50 AM
AMAlexLazarus's Avatar
Former Vendor
Originally Posted by bjbsav
Thanks Alex.
Ben,
You're very welcome-Let me know if there's ever anything else I can help out with I'm a PM away!
Alex
Old Jul 24, 2014 | 08:07 AM
shouldhavegottheGT's Avatar
I've the SR springs installed. Stock struts and mounts. I didn't even need am alignment. No uneven wear. I just picked up some 20x8.5 Giovanna Kilis and noticed that the rear is off. In going to pick up an adjustable panhard bar soon. The ride is great and looks 100x better. I don't plan on tracking or anything so stock struts and shocks are fine until they wear out. Then I'll pick up some better one.
Old Jul 24, 2014 | 08:10 AM
bjbsav's Avatar
Just want to let everyone know that Alex from American Muscle has given me all the information I need and made everything right.
Old Jul 24, 2014 | 08:12 AM
bjbsav's Avatar
Thank you. I picked up a panhard bar also to have installed and I hope everything turns out great.
Also thank you again for everyone's input.
Old Jul 24, 2014 | 08:44 AM
Former Vendor
Keep me in the loop if anything else comes up! I'll want to hear about it! Enjoy the panhard bar, it really helped and gave me and the Bullitt a lot more confidence in the twisties...maybe too much!
Alex
Old Jul 29, 2014 | 09:48 AM
MADSCOTSMAN's Avatar
Originally Posted by houtex
But you *may* find out you need an adjustable panhard bar to reset the rear axle, as lowering the car in the back will push the axle out to the driver's side. It's a looks as well as a thrust angle issue, that. And you *may* find out that your camber is out of whack and will need camber bolts or camber plates. Read on...
Anything lower than 1.5" (and I suspect anything over 1", really), and you're for sure talking having to change camber, because the suspension will tilt the wheels inward at the top (or outward at the bottom, whatever) and that'll cause a lot of wear on the inside of the tire, and cause premature tire retirement. rotation will help forestall it a little, but wont cure it, and at the very least, camber bolts are something to look into... but they only go so far. A caster/camber plate is a better solution for majorly lowered cars for the front suspension.
FWIW, on my 13' I went with the 05-10 style Koni yellows and the GT500 strut mounts. If you mount those strut mounts 180 degrees out (indicator arrows pointed out toward the wheels instead of OEM in toward the engine), then you do NOT need camber bolts or plates to get the camber within spec. If you choose to go with they 11-14 struts, you cannot use the gt500 mounts (because of the aforementioned change in the upper strut shaft diameter and threading), and WILL need camber bolts/plates.
Old Jul 29, 2014 | 09:59 AM
Brandon302's Avatar
You can do the same mounting wizardry with the stock 11-14 strut mounts with the same results.
Old Jul 30, 2014 | 08:26 AM
bjbsav's Avatar
Well I ended getting it done yesterday.
Before
IMG_0138 by benbrengman, on Flickr
After
IMG_5017 by benbrengman, on Flickr
Old Jul 30, 2014 | 06:27 PM
dmichaels's Avatar
Looks great!! How do you like the ride?
Mine have been great - have put on ~350 track miles on mine plus ~2000 street miles so far. Nothing but good things to say
Old Jul 30, 2014 | 08:48 PM
bjbsav's Avatar
So far they I like the setup. Nice ride.
Old Jul 30, 2014 | 10:59 PM
MDkid92's Avatar
Looks good. They go really well with 20's. I need that to be my next upgrade! For a cheaper set of springs, they seem to ride very well.
Old Jul 31, 2014 | 05:40 AM
bjbsav's Avatar
They do ride pretty well. This is my daily driver when I am not on the motorcycle. If you see me on a track it means I took a wrong turn.
5.M0NSTER
26
Sep 28, 2015 07:11 PM
14BlackGT
23
Sep 11, 2015 04:57 AM
RocStar69
Aug 21, 2015 07:33 AM
dohc97
Aug 3, 2015 06:26 AM
