Shoot holes in my plan
Steeda SportsKoni Str.t
Steeda hd strut mounts
Whiteline adj PB + brace
Whiteline UCA
Steeda billet LCAs
That's the list as of today haha; seems to always be changing. I'm wondering if I need adjustable LCAs with this proposed rig, as the drop will be </= 1.25".
Also like the idea of low maintenance bushings - not going for a hard core track setup. My S2000 is loud and unbearable on the highway. Imagine driving in an uninsulated bathtub with the wheels bolted directly to the chassis and you'll get the picture.
I'm looking to make this into a competitive car for track and street use. Not into dragging, but being able to stick from a dig wouldn't hurt- but not at the expense of cornering.
At some point I'm going to want wider wheels/tires. At least 295s out back. Possibly 275s up front. Maybe a square setup with 275s.
Criticism and advice welcome.
Whiteline UCA
Steeda billet LCAs
Whiteline UCA
Steeda billet LCAs
Whiteline UCA
Steeda billet LCAs
I have read in several places that the only way to run a square set up is to have a stiffer front sway, I believe, otherwise you get oversteer. I am also in the same dilemma about adjustable LCA's, I just decided I would prefer to buy one product and keep it and be able to use it to it's full advantage down the road. So I decided on the Whiteline LCA's because I don't want to eventually need an adjustable LCA and have to purchase a new set.
I totally get your point about "down the road" flexibility; one day I may decide I need relo brackets, though I've seen the LCA angles on cars running Sport springs and the difference compared to stock is almost negligible.
From what I've seen, the Whiteline gear is the t!ts and likely what will be bolted onto my car (I’m still intrigued by the Fays2 Watts Link). I'm going to have to drive it stock for a couple months, but that will give me time to ponder future mods.
I [believe] the GTs are already set up with ideal sway bars for a square setup.
Whiteline has a Watts too FWIW.
Edit: WL Watts Link is plug and play. Disregard the original message - that applies only to GT500.
Thanks, guys.
Wheelman, yah- I think I've read that some fab is required for the diff cooler to work with their watts.
Thanks, guys.
Yep - From what I've read, the breather and oil cooler have to be accounted for. The amount of fab work isn't extensive, but it's nothing I'd want to deal with. I really wanted this one, but will end up with the Fays2 if I get one at all.
the Watts Link is 100% plug and play with anything other than the 2013 GT500 trackpack, as the standard Mustang track pack does not include the relocated breathers or differential cooler that the GT500 has.
Great, thanks for the clarification. No need to mod my mod list then.
Do you happen to know if new bolts come with some of the White Line parts? For instance the PHB bolt I believe is a one torque use and since I will be switching to a White Line piece will the PHB bolt be supplied?
No they don't come with replacements bolts like the PHB or LCA's. To be honest, you can use them a few times, nothing a little loctite can't cure. I change stuff out all the time and have never had an issue.
Also the whiteline watts link is an amazing piece of quality. We've put a few on and it just takes some patience and time. You'll be very happy with what it can do for you however, if your car is just a DD than it may be a bit of an overkill. Your overall kit is great and will transform your car. No reason to shoot holes thru it. Also the Steeda HD mounts are beefy, I've used them in the past and can tell you they're pretty impressive.
Would the Steeda mounts be recommended for occasional track use? I am trying to put a similar list together but wasn't sure if the mounts would be needed. Are the mounts similar to caster camber plates? If so I think I would just wait to get a set of CC plates.
The HD mounts allow for +- a degree of camber adjustment, they really are a great set of mounts. For the time being the GT500 mounts would work and with a drop not too aggressive they would work just fine. The Koni STR.T are a great set of entry level/ OEM replacement shocks that do very well with lowering springs such as the steeda sports.
Gotcha, now I know where you're getting at. Depends on what you want to do with your mustang. The Steeda HD mounts do have some camber adjustment, although it may be limited if you're someone who likes to run aggressive camber. If your vehicle see's the track seldomly and is mainly a DD the Steeda HD strut mounts will do just fine.
For me, I like the Ground control CC plates. With Billet tops, included spring isolators and the ability to adjust -+ 3 degrees of camber it leaves you with many options. There have been a couple cases of individuals breaking the bolts of these plates during installation. I've personally installed around 10 of these and have never had an issue. For $350.00 shipped, you get a lot for your money going with GC.
