Koni Yellow drag strip settings
Old Mar 22, 2012 | 08:47 AM
m4a1mustang's Avatar
Need a bit of advice here. I am heading to the drag strip tomorrow and am trying to determine what would be ideal settings for my Koni yellows.
Part of me says I should keep them soft for weight transfer but another part of me says I should keep them on the firm side in the rear to keep the rear axle planted.
Thoughts?
Old Mar 23, 2012 | 01:42 PM
corruptor's Avatar
Thoughts?
I would start full soft front, full stiff rear and adjust from there.
Old Mar 23, 2012 | 03:52 PM
UnrealFord's Avatar
I agree.
Old Mar 24, 2012 | 08:52 AM
Thanks guys. I tried anywhere from full soft to full stiff in the rear. I think full soft ended up being the best (1.93 & 1.94 60's vs 1.97-1.98 at full stiff). But the real problem is street tires. Such a waste of time.
I had a best of 12.56 @ 113. DA was about 1400-1500 so all things considered that's OK. I'll be back in the fall with ET Streets.
I might do something with these 3.73s as well. Thinking 3.55 as a compromise.
Old Mar 24, 2012 | 11:54 AM
Interesting. I was thinking full stiff in the rear would lead to wheel hop. But I understand full soft in the front helps weight transfer.
Old Mar 24, 2012 | 12:02 PM
It did feel like the 1-2 shift was a little more on the hoppy side with the rears at full stiff. It was a frustrating day regardless of how I set the shocks. I ran 12.56-12.61 all day. At least I'm consistent.
Old Mar 24, 2012 | 07:30 PM
Call me bored, but I did a little comparison to my last outing when I was bone stock. DA on that day was very low, around 0-100.
10/22/10
Best 1/8 ET 8.369, std. deviation .064 seconds (11 runs)
Best 1/4 ET 12.87, std. deviation .085 seconds (11 runs)
3/23/12 - CORRECTED
Best 1/8 ET 8.221, std. deviation .032 seconds (12 runs)
Best 1/4 ET 12.562, std. deviation .044 (12 runs)
3/23/12 - CORRECTED (using 1400 DA factor, multiply ET by .9848)
Best 1/4 ET 12.37, std. deviation .043 seconds (12 runs)
Looking at uncorrected times, I improved my best 1/8 ET by .148 seconds. I increased my best 1/8 MPH by 3.63 MPH.
I improved my best 1/4 ET by .308 seconds and increased my best 1/4 MPH by 2.7 MPH.
I improved my best CORRECTED 1/4 ET by .498 seconds and my best CORRECTED 1/4 MPH by 4.15 mph.
These gains seem to be consistent with what you'd expect when the only power mod is a Steeda CAI + Tune. The slight improvement in the 1/8 ET is telling me that I really need to improve my traction situation if I want to bring my times down.
Here are the full uncorrected best runs from my two previous visits:
10/22/10 - Stock
60' 2.017
330' 5.519
1/8 8.369
MPH 84.29
1000' 10.824
1/4 12.87
MPH 110.31
03/23/12
60' 1.993
330' 5.456
1/8 8.221
MPH 89.15
1000 10.585
1/4 12.562 (12.371 corrected)
MPH 112.73 (114.49 corrected)
Any thoughts? I'm happy that I'm fairly consistent.
kponypower
Jun 17, 2020 07:17 AM
trackpack13gt
Jul 25, 2017 05:29 PM
GLOCKer
Sep 28, 2015 05:20 PM
AJ_Trevino15
Sep 28, 2015 07:51 AM
