How long should I wait for my new suspension to "settle in"?
Old Mar 23, 2016 | 05:23 PM
ZeeGT's Avatar
I just upgraded my suspension with Steeda Ultralites, Steeda HD Strut Mounts, Steeda ChroMoly LCA's, Koni STR.T shocks and struts, BMR Panhard bar and LCA relocation brackets. I also swapped stock 255/40/19 tires and wheels for 255/45/18 and 285/40/18 and also got an alignment done.
It's been a couple of days but right from the start I've been hearing a chirping on the front driver's side. Sounds like little birds in the wheel well. It happens almost constantly, over smooth roads, bumps, rough roads, etc. Tried locating the source of the noise and it's almost like it's the spring or thereabouts. Just today I also noticed a sort of light thumping coming from the front passenger's side. My GT is a daily driver so it's really annoying to hear this all the time.
So my question is, should I wait? Or should I have it checked out right away? If I wait, for how long?
Old Mar 23, 2016 | 05:42 PM
Mr. V's Avatar
Id have it checked out now. It shouldn't make odd noises from day one. The way it feels when you drive it and adjusting your settings is something you wait for. Noises are not.
Old Mar 23, 2016 | 07:13 PM
tj@steeda's Avatar
Hello Zeegt,
I have asked our install dept. to take a look at this thread & see if anything jumps out at them - previously, there were some issues with the front lower control arms & the bushings.
Does this thread sound similar to your issue? https://themustangsource.com/forums/...squeak-522954/
Best Regards,
TJ
Old Mar 23, 2016 | 08:03 PM
ZeeGT's Avatar
Originally Posted by tj@steeda
Hello Zeegt,
Best Regards,
TJ
TJ, thanks for looking into this. I had read that thread when researching possible causes but I'm pretty sure that's not the cause in my case since the source of the chirp seems to be high up in the wheel well right around the spring and the noise can be reproduced even when the car is cold.
Old Mar 24, 2016 | 07:26 AM
ZeeGT's Avatar
Hello Zeegt,
Best Regards,
TJ
TJ, I did a little more research and if I push on the driver's side front fender the noise happens on rebound but not on compression and Koni has told other people with this exact same issue that tolerances between the shaft and housing are really tight and that by putting some silicone grease on the strut shaft the noise should go away. I'll be trying that out today to see if it works.
Old Mar 24, 2016 | 02:26 PM
tj@steeda's Avatar
Also check if the the upper strut mount is seated properly ... that is what our installers wanted you to check.
Best Regards,
TJ
Old Mar 24, 2016 | 02:37 PM
ZeeGT's Avatar
Best Regards,
TJ
TJ, took it to another shop today. The installing shop was kind of busy. The new shop said it was the ball joint. I had noticed some mild bumpsteer so I decided to get the balljoints and bumpsteer kit from you guys. Hopefully this fixes it.
Old Mar 24, 2016 | 06:13 PM
tj@steeda's Avatar
Unfortunately, it is one of those things where it is very hard to diagnose without actually seeing the car - please keep us updated & also double check the strut.
Best Regards,
TJ
Old Apr 2, 2016 | 02:48 PM
ZeeGT's Avatar
Best Regards,
TJ
TJ,
Had the car checked out by the original installer today. One of the mounts wasn't set right. Unfortunately that was not the cause of the noise. It seems the strut is bad and squeaking. Aside from that, I have to say that the springs, strut mounts, LCA's and other parts from Steeda make the ride 1000% better than stock. The car feels crazy glued to the road, and 100% more stable. My occasional wheel hop is gone, as is the swaying when turning, squat when accelerating, and dive when braking. I still have to install the X11 Balljoints and Bumpsteer kit, but I have no doubts the will make the ride even better.
Thanks!
Old Apr 2, 2016 | 04:32 PM
Mr. V's Avatar
TJ,
Thanks!
Please post a review of the bump steer kit and ball joints when you are done. Id love to read it. This among many other mods keeps jump on and off of my list.
Old Apr 2, 2016 | 08:32 PM
tj@steeda's Avatar
TJ,
Thanks!
Glad to hear it & hopefully ... the squeaking can soon be taken care of!
I will pass along the feedback to our install team as I have been keeping them apprised of your feedback.
Best Regards,
TJ
Old Apr 3, 2016 | 02:42 PM
ZeeGT's Avatar
Will do.
Old Apr 19, 2016 | 11:32 AM
ZeeGT's Avatar
Mr. V,
After lowering the car and swapping wheels/tires the steering felt loose and light, it even had a little play when turning the wheel and of course had some bumpsteer. Nothing major, but noticeable over bigger road imperfections or bumps. I guess the looseness could be attributed to going to smaller/lighter wheels.
After the install of the Bumpsteer kit everything is nice and tight again and more importantly no bumpsteer. Steering feels responsive, accurate, and without play. I kind of think that it actually feels tighter than stock. I also had the Ford Racing (M-5490-HWB) Complete Anti-Roll Bar Hardware Kit installed at the same time as the bumpsteer kit and maybe this helped get that tighter than stock feeling but in any case I think the Steeda Bumpsteer kit is a good investment. I still have to get the Balljoints on the car (miscommunication issue with shop) but I'll post here when I do.
Old Apr 23, 2016 | 11:22 PM
PonyMuscletang13's Avatar
After lowering the car and swapping wheels/tires the steering felt loose and light, it even had a little play when turning the wheel and of course had some bumpsteer. Nothing major, but noticeable over bigger road imperfections or bumps. I guess the looseness could be attributed to going to smaller/lighter wheels. After the install of the Bumpsteer kit everything is nice and tight again and more importantly no bumpsteer. Steering feels responsive, accurate, and without play. I kind of think that it actually feels tighter than stock.
I did not know such thing as bumpsteer or the 'bumpsteer kit' ever existed until this post. So this is what I needed then.
After the new wheels n tires (car was already lowered) the steering wheel felt loose. I asked around including the performance shops, even posted a thread here but never got the clear answer. Getting the alignment done, along with lowering the tire pressure did helped tightening the feel a bit.
I should look into getting this kit installed soon. Does the kit also feel confident at high speeds or at woot?
Old Apr 24, 2016 | 03:50 PM
ZeeGT's Avatar
At highway speeds (60 -75) the car feels smooth as silk. At WOT I usually pay more attention to the rear end than the front end, but so far so good...
Old Apr 28, 2016 | 03:32 PM
smike308's Avatar
ZeeGT--Did you ever get the original problem fixed?
Old Apr 28, 2016 | 07:43 PM
ZeeGT's Avatar
smike308, sure did! Chirp was a bad strut and the thumping was a badly seated strut mount. Also had some rattling in the rear end and the FRRP sway bar bushing kit took care of that. Thanks for asking!
SpeedCostsMoney
Mar 21, 2016 10:55 AM
99TA5.7@gmail.com
Feb 26, 2016 09:18 AM
99TA5.7@gmail.com
V6
Feb 23, 2016 01:44 PM
