Anyone using Steeda Pro-Action shocks/struts?
Old Mar 14, 2014 | 04:45 AM
silverstate777's Avatar
I’m looking to firm up the ride in my ‘14 GT daily driver base model and do not have any plans to lower it. I’m running the 235/50/18 Cooper RS3-A tires otherwise the suspension is bone stock and a bit “floaty” for my liking. I’m thinking that these would get the job done:
http://www.steeda.com/store/steeda-p...s-555-8405-11/
Anyone using these? If so, any pros/cons to share?
Old Mar 14, 2014 | 05:19 AM
Ajcruz1's Avatar
I have the Steeda Pro-Action shocks & Struts and they work great for me. Nice ride and I have them paired with BMR springs. Why are you not wanting to lower it? That would help with the floating also.
Old Mar 14, 2014 | 07:17 AM
My ‘14 GT has already had a couple of ground clearance issues that my ‘12 V6 w/bone stock suspension never had while traveling on the same route for the past 2 years. I can only assume that my GT sits lower than my V6 did, but never took any measurements to compare the two. So, it’s probably not in my best interest to lower the GT and further reduce my ground clearance as it's my daily driver.
Old Mar 14, 2014 | 02:03 PM
tj@steeda's Avatar
You will be very happy with the Pro Actions. It's the only shock we build. Extensive product development and testing just on Mustangs. Best possible valving for street and track use. made in the U.S.A. Comes with a Lifetime warranty.
Let me know if I can help you get a set?
Best Regards,
TJ
Old Mar 14, 2014 | 04:24 PM
mikeyt03's Avatar
I've had koni strt's and pro actions and prefer the pro action ones. But, the strt's are a little stiffer.
Old Mar 14, 2014 | 04:28 PM
Ajcruz1's Avatar
Yep I have Koni yellows adjustable and they are pretty much the same as the STR.T on full soft. They are a stiffer ride than the Steeda ones but not by much.
Old Mar 14, 2014 | 06:15 PM
Thanks for the replies.
TJ: Check your PM's
Sep 30, 2015 07:02 PM
GeoWett
Sep 30, 2015 06:40 AM
Sep 24, 2015 08:15 PM
Sep 16, 2015 06:44 PM
Sep 10, 2015 12:44 PM
