View Poll Results: best tire size to mount on 18x10 wheels (squared)
285/40R18
42.86%
285/35R18
57.14%
Voters: 7. You may not vote on this poll
285/40R18 VS 285/35R18 square setup
Old May 10, 2014 | 01:47 PM
M3hunter's Avatar
Question 285/40R18 VS 285/35R18 square setup
Hi Guys,
To fit to 18x10 wheels for a squared setup for best handling with good looks and not rub issues, what do you think it will be a better fit: 285/35R18 or 285/35R18 square set ups? Why?
Old May 10, 2014 | 02:52 PM
Womprat's Avatar
Having had run the 275-40-18 setup on the '05 and now running 275-35-18 on the '07 have to say lower profile for more aggressive cornering. the first rubbed only at full wheel lock, otherwise no issues.
Old May 10, 2014 | 10:38 PM
BaknBlk's Avatar
I'm running 19X9.5 with 285/35/19's square....no rubbing at all...I know you asked about 18's, but just giving you a reference.
Old May 12, 2014 | 07:30 PM
M3hunter's Avatar
From what I read on your replies, basically the 285/40 will be for good looks and the 285/35 for better handling.
Old May 13, 2014 | 08:57 AM
Brandon302's Avatar
Go with less sidewall, it's the difference of maybe an inch probably with the 40 and the handling is better with the 35.
Old May 13, 2014 | 07:35 PM
M3hunter's Avatar
Thumbs up
Yes I think that for track usage the 285/35R18 mounted on 18X10 wheels will be the best choice. Still I will keep my 275/40R19 for daily driving. Thanks Guys, for all your comments.
Old May 16, 2014 | 01:52 AM
dmichaels's Avatar
With 3.73's I would opt for the 40 profile for a bit more speed in each gear. In my opinion the 3.73's generally a bit too short for road courses. I think 3.55's are perfectly suited, too bad they were not an option with the track pack
I have run 40 profile tires and 45 profile tires and there is not much difference unless you are on a race ready suspension. The Koni and steeda setup you have should do well and I would be impressed if you noticed a difference between 35 and 40 profile tires.
Old May 17, 2014 | 06:48 AM
M3hunter's Avatar
Thumbs up
Yes DMichaels, I think you made a strong point. For my DD that it was the reason I went with 275/40R19, instead of 35's, I heard many comments on Mustang forums that 1st. shift was useless with the combination of 3.73 gears & 35's profile tires.
I did not choose the 3.73, it came with the car. Like you say, probably the 3.55 or the stock gear should be better for the track.
K.A.I.N
13
Dec 26, 2015 01:29 PM
Airborne42
Sep 25, 2015 05:14 PM
MustangGTCS13
Sep 17, 2015 07:38 AM
