2012-2013 BOSS 302
TSBs and other Issues
Old Jul 22, 2011 | 01:10 AM
MyStang2010GB's Avatar
Thought we might want start a thread about TSBs, software updates and other important service / maintenance issues we might all want to know about. So if you have found a TSB or taken your ride in for a software update..... Let us know here so we can all be informed. I would suggest if you have the TSB# add a short description as to what it is for. If you had a software update please let us know what it was for as well.
Just a thought!!
Old Jul 22, 2011 | 02:05 PM
ShaneM's Avatar
i have the sticking clutch pedal issue on and off and the rear end whine. i also have this issue where my right foot can't seem to keep the pedal from going down too far and killing fuel economy.
Old Jul 22, 2011 | 02:08 PM
SoFlo Mustang's Avatar
Op, u shud update ur post and make a list for every1 as they are posted
Old Jul 22, 2011 | 05:14 PM
Bueller's Avatar
You can always have the dealer reprogram the delivery-mode tune back onto your ECU, complete with retarded timing and the rev limiter set to what seemed like 3k RPM. Anyone else drive their Boss with this delivery tune still active? It was downright dangerous.
Old Jul 22, 2011 | 06:50 PM
ShaneM's Avatar
yes when i picked up the first boss i had i nearly got ran over trying to merge onto the highway leaving the dealership. floored it and nothing. i figured it was a delivery thing like the Shelbys. after 50 miles it got sideways trying to merge onto the next highway because i did'nt expect it to go yet.
Old Jul 24, 2011 | 09:40 AM
Roamer's Avatar
Rear window is distorted on mine. Plan to get it into the dealer for replacement under warranty. It's like a fun-house mirror at the circus.
Old Jul 24, 2011 | 09:50 AM
phiggs54's Avatar
I think my Boss had a retarded driver behind the wheeel after delivery. But after 100 miles the problem slowly started to clear
Old Jul 26, 2011 | 12:06 PM
mtnbikefuel80's Avatar
subscribed
Old Jul 26, 2011 | 01:08 PM
black_bullitt's Avatar
Per this thread: https://themustangsource.com/f813/fr...496351/index2/
TSB 110708A/B
I just had my LCAs replaced this morning per the bulletin. No issues, no questions, they just did it. Brought the car in for the initial check on Friday, parts were ordered, got a call Monday saying the parts were in, dropped the car off 0730 Tuesday, picked it up at noon. Done.
FORD:2011-2012 Mustang
ISSUE:
Some 2011-2012 Mustangs built on or before 4/1/2011 may exhibit a grunt/creak/chirp/squeak noise from the front lower control arm hydro bushing. These noises may occur over large vertical bumps like speed bumps, pot holes, rough roads and driveway approaches.
ACTION:
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
Use chassis ears on the lower control arm hydro bushing bracket tabs to verify noise is coming from the hydro bushing. The hydro bushing is the large diameter bushing at the rear of the control arm.
If the noise is not confirmed as coming from the hydro bushing, do not continue with the article. Refer to Workshop Manual, Section 204-00 for normal diagnostics.
If the noise is confirmed as coming from the hydro bushing, replace the lower control arm that is making the noise. Refer to WSM, Section 204-01.
PART NUMBER . . . . . PART NAME
CR3Z-3078-A . . . . . Arm Assy - Right Front
CR3Z-3079-A . . . . . Arm Assy - Left Front
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT: Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION . . . DESCRIPTION
110708A . . . . . 2011-2012 Mustang: Replace One (1) Lower Control Arm, Includes Time To Diagnose (Do Not Use With Any Other Labor Operations)1.2 Hrs.
110708B . . . . . 2011-2012 Mustang: Replace Two (2) Lower Control Arms, Includes Time To Diagnose (Do Not Use With Any Other Labor Operations)1.6 Hrs.
Old Jul 26, 2011 | 03:10 PM
atrain1975's Avatar
TSB 110708A/B
PLEASE TELL ME THE NOISES ARE GONE!! My LCAs are being replaced tomorrow.
Old Jul 26, 2011 | 03:29 PM
askjeffro's Avatar
Based on his response it certainly sounds like the problem has been remedied for him.
Old Jul 26, 2011 | 03:40 PM
Jza1736's Avatar
fixed fast
Old Jul 26, 2011 | 07:30 PM
Being that the noises in question were sporadic at best, I will hold judgement for a few more days. I will be getting another phone call from Ford Customer Service on Friday to check up, but so far, yes, all indications are that this fixed the issue. I'll post up if I experience anything to the contrary later on.
Old Apr 10, 2012 | 12:42 PM
dean_acheson's Avatar
Bump.
Road_Runner
Sep 2, 2024 04:46 PM
kponypower
Jun 17, 2020 07:17 AM
09-gt/cs
Oct 15, 2015 10:03 AM
Antigini-GT/CS
Oct 5, 2015 09:43 AM
