Track wheels and tires
#102
I love all of you guys out there pioneering what works and what doesn't! Let's us mere mortals sit on the sidelines in a wait and see mode and then jump-in when the best combos are found. Keep going!!
#104
I will be running 275/40/18 BFG G-Force TA K/Ds on a set of Roush RR03 wheels. Picked them up at the garage sale for track duty, couldn't pass them up.
Once I'm comfortable with the car and my abilities, I plan on moving up to a set of Hoosiers for track days.
#105
BTW the rims and 555's were like $1200 shipped. Good luck but DO NOT take my word as the final chapter, I am doing this for cost saving and just some driving fun, just about everyone on the forum knows more then me at this point. I can only pass on what I have done as a beginner.
Lots of good info my a$$ my head is literally gonna explode! Ah what the hell keep it coming even if I am too old to take it all in
#106
Dave
#107
I can't do external reservoirs and stay in TTB, not sure if the ClubSports are or aren't (apparently some models are, not sure bout the Stang).
Penske's are pricey:
http://www.hrpworld.com/index.cfm?tp...action=product
http://www.resuspension.com/Penske-o...p-1-c-286.html
#108
IMO, I would say the entry level 4000 series AST's are comparable to the KW Clubsports. I don't have first hand experience with KW's just competitors who have run them, but I do with Moton DA Clubsports (now owned by AST). I ran Moton's on my STU prepared Evo for 3 years and would recommend them. In fact, Moton would have been my alternate choice for the Boss. Very good support and quick turn-around for rebuilds and custom damping. Anyone looking for a good shock package between Koni and upper-end shocks should keep watch for Bilsteins that will be popping up soon. I believe with their new dual bleed shaft (DA).
Dave
Dave
#109
1 Post
In any event, carry on Lewis & Clark!
#110
#111
FR500C dampers, $5900 for the set.
FR500S dampers, $5450 for the set
#112
The mustangs I have tracked locally have Falken tires on GT-500 wheels. no stagger. Bulletproof combo IMO. They slip predictably, and let you know audibly when they're on the edge. I ran one car on 8 30 minute sessions of hot lapping and could have continued for many more days on the tires.
#113
Not sure if those are a straight swap to street vehicles, though (not that I'd ever consider that amount of money for shocks, really).
#114
I'm gonna run a 275/40/18 square setup for the first track event, we'll see how I like it. Maybe I won't need to trail brake as much.
If the car is prone to snap oversteer, a Strano adjustable rear swaybar will be installed. Square setup is very beneficial for tire rotation and life.
#115
One warning, and Sam confirmed this, the adjustable bar doesn't work with LCA relocation brackets, apparently not any of them (mine were CHE, and needed to remove them as too many points in TTB, so no big deal.)
That may be the reason Steeda's bar has the mounting tab piece, to avoid that interference. Course, that would surprise me greatly as Steeda stuff never seems to work with any of their other pieces. I got their billet front AR brackets (UMI ones on Sam's site much better, w/ Zerks), and the brace pieces to bolt the AR bracket to the front subframe, and they won't fit together -- had to grind the tabs down on the braces to fit inside the brackets, not a good solution.
Then, got their lightweight radiator support, come to find out none of them fit at all with this piece! The AR brackets bolts aren't the stock separation, so the billet bracket won't fit, and it's a bit further forward, so the braces don't fit. Whatta rip off! One of the Steeda reps on a different forum had noted this, said they'd replace my bar or bracket or whatever with the new 'updated' ones, but I figured it wasn't worth the hassle.
Gonna put the billet pieces and the braces up for sale now.
#116
Good info there about the fitment thx
#117
#118
I hear ya, I'm ready to sit and watch for a while now The suspension "works" for me right now, and I figured the same thing, change one part and all the tuning goes out the window. I'm waiting for a "sorted" out solution before I go there. I wonder if just going the 302S route (for complete suspension setup) is a viable option down the road?
#120
