2012-2013 BOSS 302
Top strut nut torque spec?
Old Mar 5, 2013 | 03:42 PM
Brandon302's Avatar
I will be installing FRPP P springs, Whiteline LCA's, PHB, relo brackets, and GT500 hats tomorrow, however the only info I haven't been able to find is the torque spec for the strut nut that connects the hat to the strut. I wasn't sure if this was something specific to the Boss since the struts are different then a GT. Does anyone know if it is different and if so what it is?
Old Mar 5, 2013 | 05:05 PM
JScheier's Avatar
48 ft/lb is what I show with a note NOT to use an impact wrench for installation.
Old Mar 5, 2013 | 05:19 PM
Brandon302's Avatar
Thank you, I saw the torque spec on the FR3 handling package was 46 ft/lb and for some reason I thought that was low. That seems to make sense though.
Old Mar 5, 2013 | 06:30 PM
cloud9's Avatar
I was told 46-50 by FRPP when I called.
Old Mar 5, 2013 | 06:49 PM
I used an impact on mine
Old Mar 5, 2013 | 06:55 PM
cloud9's Avatar
Paint mark the nut and use loctite. I had a couple back out last year.
Old Mar 5, 2013 | 07:02 PM
Brandon302's Avatar
Good to know, not good to hear though, I will be using thread locker on all the bolts, I am also reusing the stock bolts since this would be the first time they have been taken off.
Old Mar 6, 2013 | 08:27 AM
Brandon302's Avatar
Currently finding that the GT500 hats everyone suggests don't fit the Boss struts, anyone else had the same issue or just used the stock hats?
Old Mar 6, 2013 | 05:53 PM
JScheier's Avatar
Using an impact on adjustable dampers where the adjusting mechanism is on the shaft is bad ju-ju.
^says the person that has done it 100 times and only jacked up the adjusting mechanism on Koni's about 99 of them
Note: make sure to use a really, really good wrench on the hex portion of the shock... round that off (Konis) and the impact suddenly becomes your only option for removal (see above).
Old Mar 6, 2013 | 06:10 PM
I don't have the adjustables is it still bad?
Old Mar 6, 2013 | 07:21 PM
Brandon302's Avatar
I used an impact to put it on, hopefully no damaged. Ended up grinding out a 13/16 spark plug socket so I could fit a socket inside it. Was able to tighten down the strut this way.
Old Mar 6, 2013 | 07:35 PM
texastboneking's Avatar
Bear Eats King...
Bear ****s Bone
Lol.. I used impact. Car rides fine
Old Mar 7, 2013 | 03:13 PM
JScheier's Avatar
You should always follow the manufacturer's instructions... but for the most part, using an impact on non-adjustable dampers is OK. Many adjustable dampers use a J-hook mechanism internally to make the adjustments... spinning the shaft with an impact can damage the J-hook causing imprecise or non-existent adjustments.
If you ever turned the **** on a single adjustable Koni and felt resistance, or the **** turning back, you've most likely damaged the internal adjuster.
Tokicos use a slightly different mechanism, but spinning the shaft can still lead to damage. From what I've seen, it's usually that you can't adjust into the upper range (4-5).
Old Mar 7, 2013 | 03:32 PM
Brandon302's Avatar
Good thing I left it on 5 for the fronts. Do they sell special tools for installing the rod nut?
May 3, 2026 05:42 AM
Road_Runner
Sep 2, 2024 04:46 PM
RoushRS3
Sep 29, 2015 08:03 PM
AJ_Trevino15
Sep 28, 2015 07:51 AM
