2012-2013 BOSS 302
Spare tire
Old Apr 26, 2013 | 07:04 AM
Locke62's Avatar
Spare tire
Guys, I just looked in my trunk and found nothing but a little gadget, what is that. I didn't look at he Manuel yet. Please advise?
Old Apr 26, 2013 | 07:10 AM
CrazyBrain's Avatar
its an air compressor, with fix-a-flat stuff inside. it only shows where the hole is, it doesn't fix anything. I know this because I got to use mine within the 1st 150 miles of owning my Boss. get an old school tire repair kit and put that in the trunk with it.
Old Apr 26, 2013 | 10:31 AM
bigbossman's Avatar
Here's a spare tire thread if you're interested:
https://themustangsource.com/f813/sp...firmed-495464/
Old Apr 26, 2013 | 10:15 PM
SBYBoss's Avatar
I've been searching for a good spare option. I don't like the description of the spacer thingy on this one - seems like it could be a problem on the roadside especially if it was dark or the weather was bad. I'm still looking.
I like road trips and don't like tire slime so need a spare.
Old Apr 27, 2013 | 08:23 AM
maddog2's Avatar
The 19" p zero fits in the wheel tub in the trunk. Thats what I have I just have to find a scissor jack now.
Old Apr 27, 2013 | 09:11 AM
SBYBoss's Avatar
Are you saying that the stock tire/wheel fits? How much does it stick up above the top of the tub?
Old Apr 27, 2013 | 11:21 AM
davesvt2000's Avatar
I use a 2007 GT500 wheel and tire, 18 x 9.5
It fits perfectly in the wheel well, and sticks up about an inch, but then you have the carpet covering it, so it really doesnt show.
I bought a jack on SVTPerformance, and took the bolt holding down the air compressor, and had it lengthened about 3 inches, to now clear thru the jack and spare, and use the round washer and wing nut on top.
Old Apr 27, 2013 | 11:24 AM
11SHELBYGT500's Avatar
If it sticks up an inch, how is that perfection?
So I take it the cover board isn't flush with the trunk floor.
Old Apr 27, 2013 | 02:33 PM
SBYBoss's Avatar
Is there a narrower wheel/tire combination that will both clear the brakes and fit flush in the wheel well instead of sticking up?
Old Apr 27, 2013 | 10:41 PM
maddog2's Avatar
Its not perfect but it works for me. If I have a flat I want to change it and move on. I am not a AAA kina guy.
Old Apr 27, 2013 | 11:01 PM
Fenderaddict2's Avatar
There's no spare tire in my trunk?!?!?
Old Apr 28, 2013 | 05:09 AM
Gabe's Avatar
It's an air compressor, but where did people get this idea that there's fix-a-flat stuff inside it?
I've used it to pump up a tire after I plugged it, and when I had the tire removed later on there was no slime inside the tire
It's just an air compressor.
Old Apr 28, 2013 | 06:39 AM
Correct. If you're now looking down into the trunk, the only thing that gives it away is the left side and right side of the carpet drops off where the cover board ends.
Old Aug 18, 2013 | 02:19 PM
JPC's Avatar
JPC
confirmed?
...so I can use this as on track side air pump?
.......no slime inside?
Old Aug 18, 2013 | 07:10 PM
Gabe's Avatar
Originally Posted by JPC
confirmed?
Somebody told me that there are 2 different hoses, one that distributes the "slime"
I've used my pump a couple of times and I don't remember seeing that second hose, but I know for sure that at least 1 of the hoses (if there are 2) distributes air only.
Old Aug 19, 2013 | 04:39 AM
Further's Avatar
There are two hoses and me has beige slime.
Old Aug 28, 2013 | 03:40 PM
yankee_pony's Avatar
I use a 2007/ 2008 shelby gt 500 wheel with a 245/45/18 tire if yiu need a wheel I have one for sale
Philcsag1@aol.com
Old Aug 29, 2013 | 09:02 AM
97GT12's Avatar
The problem is what fits in the well does not clear the brembo calipers up front. So either you live with the possibility of needing to change two tires or the spare sitting a bit high.
There is a thread somewhere referencing a thread on another forum detailing what to get from discount tire. It's an 18" Drag (brand name) wheel and the cheapest narrowest tire they carry that fits on the rim. I went that route. I put the wheel on to make sure it fit properly over the brembo caliper and then removed it. It's not a full size spare, but being a real wheel and tire it is light years better than a mini spare or fix a flat.
Found the thread:
Old Sep 7, 2013 | 07:16 AM
TMSBOSS's Avatar
Found the thread:
One other option is that if you have a rear wheel that will fix on the front over the Brenbos. You carry a tire and wheel that fits the smaller rear calipers, most do. Then if you have a flat in the rear, simply swap the spare in. If the flat is in the front, swap a srear to the front and put the spare on the rear. A bit more work along side the road assuming the flat in on the front but could be a lot cheaper.
Rando
Aug 25, 2021 11:12 AM
cozyp828
Apr 18, 2016 09:46 PM
