Replacement Pedals
My ford service person told me that you can't replace the pedal tops, you have to attach the new pedals over the originals. I bought a new gas pedal that's wider for aiding heel/toe downshifting. I plan on attaching it to the existing pedal when it arrives.
Is this Boss specific?
If not, the brake and clutch pedals usually "peel" off... It wraps around a flat metal piece which is the 'pedal' itself. The gas pedal is probably stuck on w/ an epoxy or double sided tape.....
From this photo:
Looks like they're the old "GT500" pedals.
Which means he's correct about them 'peeling' off, they're a wrap around rubber design. My GT500 gas pedal was screwed on:
I'm going to install some SRP Pedals. I guess I'm not clear on the installation. does the existing pedal have a peal-off cover or do you just mount the new pedals over / on top of hte current pedal?
The brake and clutch pedal are rubber wrap around designs, with the overlying aluminum metal glued or otherwise attached. Just grab the back part, and peel off (takes a bit of effort). Then the bare metal pedal is exposed. Will have to be drilled through with a tough bit, use the pedal as a template for where the holes go. Then the self tapping screws.
The gas pedal unscrews from the back, leaving a heavy black plastic instead of metal. Same process of mounting the replacement, just easier to drill in.
I'm thinking there might be a different way to say it, but can't come up with one...
Originally Posted by Bossdog
my son and wife will drive the Boss from time to time.
Tell her NOT to take you in the Boss if your bleeding too bad.
BUT, if I'm getting lengthening brake pedal travel, or try a panic stop, and my foot isn't far enough over that brake pedal, watch out -- especially if the car is still in gear.
So not a bad idea, having separate ones for track/street. Will caution you, though, that given the gas pedal is plastic, not sure how long it'll hold up to repeated screw in/out with the self-tapping screws. Bolts with nylocs might be a better idea, just wonder about the depth of the backside of them.
Other option might be to drill two separate sets of holes, so not the same ones are used repeatedly, over and over, with both sets of pedals.
A metal gas pedal wouldn't have that issue. Mine currently has two different sets of holes (the originals, then the closer ones) and the hard plastic held up fine to that.
That is NOT an insignificant problem -- I moved my gas pedal closer to the brake to make heel/toe easier -- my ankle doesn't flop over the way some people like to do it, so I do the medial ball of foot on the right side of the brake, and the lateral foot to blip the left side of the gas. Pedals WAY too far apart stock, but even with the closer/bigger SRP pedals it wasn't enough. So, 1/2-3/4" closer, now much more reliable/repeatable.
also OP the metal covers on the pedals of the boss are exactly like the ones that were eon my 10 gt premium. They will pp right off and you can put them back on if you want. the pedals i put on that car required drilling into the metal behind the pedal covers and attached with screws. If you don't want to have the race pedals on the car all the time just use small wing nuts on the back of your racing pedal covers and you can remove them quickly and put the factory covers back on for the street.
I can't recall the setup for attaching the gas pedal, but that is an idea, to have separate ones with each setup. Wonder how much that'd be...
here ya go, eBay, $75
http://cgi.ebay.com/ebaymotors/05-06...ht_1051wt_1165
Rando
8/25/21 11:12 AM
PonyMuscletang13
9/29/15 09:40 AM
