2012-2013 BOSS 302
Recomendations for AL 1-piece driveshaft upgrade
Old Dec 16, 2014 | 02:35 AM
LMS007's Avatar
Are most all aftermarket AL parts more or less categorically the same?
I'm convinced carbon fiber is more or less bragging rights without much of a significant improvement over AL- I can't justify spending over a G on this upgrade anyway.
Old Dec 17, 2014 | 12:21 PM
TymeSlayer's Avatar
Can't speak for all aftermarket driveshafts out there but less rotational mass is a big plus.
I have the DSS 3-1/2" DS and it took off more than 18 pounds off my Boss.
Old Dec 17, 2014 | 01:29 PM
Originally Posted by LMS007
Are most all aftermarket AL parts more or less categorically the same? I'm convinced carbon fiber is more or less bragging rights without much of a significant improvement over AL- I can't justify spending over a G on this upgrade anyway.
The main difference between the CF stuff and aluminum stuff is basically the CF DS will disintegrate in an accident, versus the AL can possibly puncture the fuel tank/cabin/or anything else, due to it being one piece.
Old Dec 20, 2014 | 07:42 PM
65sohc's Avatar
If you mean do they all offer imperceptible performance improvements, yes.
Old Dec 22, 2014 | 08:51 AM
tj@steeda's Avatar
Our unit is priced aggressively & it is a great improvement over stock!
http://www.steeda.com/steeda-mustang...-238-10002094/
53% lighter than OEM driveshaft
Lightweight aluminum one-piece driveshaft
Improved driving performance
Quicker acceleration, lower ET's
Direct bolt-in, easy installation
No increase in NVH
Best Regards,
TJ
Old Dec 26, 2014 | 02:30 AM
TMSBOSS's Avatar
I went with the DSS aluminum shaft. Removed the slop inherent in the two piece system.
Recommend.
Old Jan 3, 2015 | 11:26 AM
1 Alibi 2's Avatar
I run the other one advertised on the Steeda page on my 11..
www.axle-exchange.com
Old Jan 10, 2015 | 11:13 PM
Tigerclaw's Avatar
Had a Driveshaft Shop Alum. DS installed last week. I've incredibly happy with mine, both in the removal of the backlash I was getting from the center joint and the better responsiveness from the car. I couldn't be happier.
Old Jan 12, 2015 | 12:53 AM
NacsMXer's Avatar
Any new noises or side effects you have noticed with the new one? I've read so many mixed reviews.
Old Jan 12, 2015 | 06:01 PM
tj@steeda's Avatar
Here is a review that was just done on our driveshaft:
And, if you are concerned that you might lose some of that factory NVH, don’t sweat it.
“We have tested our driveshafts with various modification and gearing combinations and experienced no increase in NVH,” says Steeda. “We even tested this driveshaft in an automatic GT with 3.73 gears—no knocking, increased noise, or ‘clunking’ whatsoever!”
You can read more about the driveshaft here
When your ready to purchase ... you can email me at tim@steeda.com
Best Regards,
TJ
cameron2581
'10-14 Interior and Audio
Nov 26, 2015 01:26 PM
Antigini-GT/CS
Oct 5, 2015 09:43 AM
GeoWett
Sep 30, 2015 06:40 AM
M3hunter
Sep 10, 2015 09:26 AM
