Recomendations for AL 1-piece driveshaft upgrade
Are most all aftermarket AL parts more or less categorically the same?
I'm convinced carbon fiber is more or less bragging rights without much of a significant improvement over AL- I can't justify spending over a G on this upgrade anyway. |
Can't speak for all aftermarket driveshafts out there but less rotational mass is a big plus.
I have the DSS 3-1/2" DS and it took off more than 18 pounds off my Boss. |
Originally Posted by LMS007
(Post 6878729)
Are most all aftermarket AL parts more or less categorically the same? I'm convinced carbon fiber is more or less bragging rights without much of a significant improvement over AL- I can't justify spending over a G on this upgrade anyway.
(Post 6878729)
Our unit is priced aggressively & it is a great improvement over stock!
http://www.steeda.com/steeda-mustang...-238-10002094/ 53% lighter than OEM driveshaft Lightweight aluminum one-piece driveshaft Improved driving performance Quicker acceleration, lower ET's Direct bolt-in, easy installation No increase in NVH http://www.steeda.com/images/waterma...8-10001766.jpg Best Regards, TJ |
I went with the DSS aluminum shaft. Removed the slop inherent in the two piece system.
Recommend. |
Had a Driveshaft Shop Alum. DS installed last week. I've incredibly happy with mine, both in the removal of the backlash I was getting from the center joint and the better responsiveness from the car. I couldn't be happier.
Originally Posted by Tigerclaw
(Post 6886490)
Here is a review that was just done on our driveshaft:
And, if you are concerned that you might lose some of that factory NVH, don’t sweat it. “We have tested our driveshafts with various modification and gearing combinations and experienced no increase in NVH,” says Steeda. “We even tested this driveshaft in an automatic GT with 3.73 gears—no knocking, increased noise, or ‘clunking’ whatsoever!” When your ready to purchase ... you can email me at tim@steeda.com Best Regards, TJ |
